Previous Thread  Next Thread
chat icon bf-blender / Windows (2004/03/05)
jesterKing
Posted: Fri Mar 05, 2004 7:44 pm
A new CVS build is available
This CVS build has been obsoleted by a newer build
http://www.letwory.net/cvsbuilds/bf_blender_windows_20040305.zip
This is again built with MSVC7, through the use of SCons. The ODE gameengine has been enabled, as well as support for languages (International), TTF, and OpenAL support has been compiled in (although I don't seem to be able to get any sound from Blender). The zip has been scanned for viruses, and was found clean.
This has the cool splash by Blenergetic.
See URL below for a enduser formatted changelog:
http://www.letwory.org/tiki-index.php?page=BlenderProgress233
Note: this changelog is not yet update for this build, I'm waiting for a decision about centralising this kinda stuff. Please bear with us. (It'll be all clean and snazzy).
Enjoy!
IanCalvert
Posted: Fri Mar 05, 2004 9:07 pm
Thanks, JesterKing!
Downloading now...
[damn all dialups to hell]Argh, stupid ********[/damn all dialups to hell]
Im always amazed that blender is so incredible and yet it is only around 3 megs (2644 Kb zipped, this one).
Ian
jd-multi
Posted: Sat Mar 06, 2004 11:44 pm
Well I saw there is a openAL support, but it still doesn't render with video and audio combinated. When will that be fixed? I mean openal render support would be awesome when you can render video with it too. Shocked
theeth
Posted: Sun Mar 07, 2004 3:04 am
OpenAL support has always been for the game engine only, that doesn't mean it's broken.
Martin
_________________
- John Lennon
gabio
Posted: Mon Mar 08, 2004 5:44 pm
is it me or the Scons system can't compile with a mscv6? i realy can't compile with scons. always giving me the same lib error, should i get a copy of mscv7?
jesterKing
Posted: Mon Mar 08, 2004 7:40 pm
My guess is you have problems linking FTGL. If so, there is a problem with the lib from lib/windows. AFAIR it is compiled with msvc7 (correct me if wrong), so there is somewhere a call that is not available on msvc6. Recompile FTGL is your best option.
If you do so, change the Error() implementation in FTFont.h to be without const. And move the actual implementation of that Function to the corresponding .c
Recompile, and voilá, life should smile once again upon us mortals.
/jesterKing
PS. if you want to try msvc7 for free (and legally), go to http://www.winprog.org/tutorial and follow the msvc++ tute. If doing it all right you'll end up with a free C, C++, C#, Visual Basic and J# compiler set.... Legal...
gabio
Posted: Tue Mar 09, 2004 2:27 am
absolutly.
And thanks for the links, i didn't know there was such free package for .net.
the version i use to see at school is the full featured one on cd...
gabio
Posted: Tue Mar 09, 2004 4:59 am
i'm hiting a wall on that one: it's a stupid error but i can't get rid of it:
Code:
E:\SRC\BLENDER>scons
scons: Reading SConscript files ...
Using config file: config.opts
scons: done reading SConscript files.
scons: Building targets ...
cl /nologo /EHsc /J /W3 /Gd /MT /G6 /GF /DWIN32 /D_CONSOLE /DWITH_QUICKTIME /D_L
IB /DUSE_OPENAL /DGAMEBLENDER=1 /DUSE_ODE /DNDEBUG /I\usr\include /c source\crea
tor\buildinfo.c /FoE:\SRC\build\source\creator\d_buildinfo.obj
'cl' n'est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
scons: *** [E:\SRC\build\source\creator\d_buildinfo.obj] Error 1
scons: building terminated because of errors.
E:\SRC\BLENDER>cl
Microsoft (R) 32-bit C/C++ Standard Compiler Version 13.10.3077 for 80x86
Copyright (C) Microsoft Corporation 1984-2002. All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
E:\SRC\BLENDER>
scons just don't find the cl command. as you can see after i can start it from the command line and it work. all my path variable is ok. scons seem just to ignore it... it's pretty anoying when i'm so close to get it compiled.
here is my path:
Code:
Microsoft Windows XP [version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
E:\src\blender>set
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Gabio l'intense\Application Data
CLIENTNAME=Console
CommonProgramFiles=C:\Program Files\Fichiers communs
COMPUTERNAME=GABIO
ComSpec=C:\WINDOWS\system32\cmd.exe
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Gabio l'intense
INCLUDE=C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\include\;"E:\win\
msvc7\v1.1\include\"
LIB=C:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\lib\;"E:\win\msvc7\v1
.1\Lib\"
LOGONSERVER=\\GABIO
NetSamplePath=E:\win\msvc7\v1.1\
NUMBER_OF_PROCESSORS=1
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Fi
chiers communs\Autodesk Shared\;C:\Program Files\backburner 2\;E:\win\2.0gtk\bin
;E:\win\msvc7\v1.1\Bin\;C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\;C:\Program
 Files\Microsoft Visual Studio .NET 2003\Vc7\bin\;C:\Program Files\Microsoft Vis
ual Studio .NET 2003\Common7\IDE\;c:\python22
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 7, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0207
PROMPT=$P$G
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\GABIOL~1\LOCALS~1\Temp
TMP=C:\DOCUME~1\GABIOL~1\LOCALS~1\Temp
USERDOMAIN=GABIO
USERNAME=Gabio l'intense
USERPROFILE=C:\Documents and Settings\Gabio l'intense
windir=C:\WINDOWS
jesterKing
Posted: Tue Mar 09, 2004 11:16 pm
[code]
All I can think of now is that the PATH as scons find it from the config.opts is not the same, you might want to check that.
Also, if you use the free compiler package, be sure to run sdkvars.bat from the v1.1/Bin directory of that package on the same command-line where you intend to run scons from. Before doing that remove the existing config.opts
/jesterKing
jesterKing
Posted: Thu Mar 11, 2004 12:03 am
Jump to:
