external Yafray doesn't accept some texture maps
chris1
Postby chris1 » Thu Mar 11, 2004 10:43 pm
I've some problems while trying to render a primitive with a image texture. At first I just used a color. That worked fine. Then, I used some 640*480 Pixel jpeg which the internal renderer produced. This had also worked. After this, I tried to use the Yafray Output tga as map and this also worked. Now I tried to use my texture, and this DIDNT work. I also converted it into .tga but this was the same.
error: starting parser..
:roll: Yafray Crashed
could not execute yafray. Is it in path?
What is wrong? Did I use the wrong image format or not a functionable resolution?
With best regards,
Chris
Eric
Postby Eric » Fri Mar 12, 2004 12:06 am
What's NOT clear with this message?
Caronte
Re: external Yafray doesn't accept some texture maps
Postby Caronte » Fri Mar 12, 2004 12:23 am
chris1 wrote:Hi,
With best regards,
Chris
Use the full path to the texture image may help.
Caronte.
http://www.nicodigital.com
Return to “Rendering”
