Previous Thread  Next Thread
chat icon How to import .bvh to the existing armature?
SkyMasterX
Posted: Mon Aug 09, 2004 6:05 pm
Dear all,
Is it posible to import .bvh (mocap) to the existing armature? Please help.
SkyMaster
sten
Posted: Mon Aug 09, 2004 6:15 pm
I know with the latest Blender 2.34 has a import script for .bvh files, but how to make it work I dont know...
check File ---> Import ---> Motion Capture .bvh
SkyMasterX
Posted: Mon Aug 09, 2004 6:52 pm
I tried that. It can import .bvh perfectly by create the hierachy of empties with IPO movement.
However, I do not know how to link these empties to the bones. Could anyone explain the process that I can use these empties IPO to apply to each bones of my armature?
Please help.
sten
Posted: Mon Aug 09, 2004 9:08 pm
you could try to start read here about "constraints"
http://www.blender.org/modules/documentation/htmlI/x7045.html
at the end of a armature in posemode, add an extra bone at the tip as a ika-guide, and to that one you can have a empty to parent it to..
so, Posemode --> select outer guidebone...in constrainpanel, add the name of the empty you want to have the movement as the bvh has...I hope it will help some...more docs in a link below:
http://www.blender.org/modules/documentation/htmlI/c6624.html
sten
Posted: Mon Aug 09, 2004 9:11 pm
btw...I moved this topic to "Animation" forum, it is better placed there Smile
but actually, these questions are better answered (as a user) over at www.elysiun.com, but I dont know if your question/s are development rated...
well, good luck Smile
ideasman
Posted: Tue Aug 10, 2004 1:23 am
Hi, I wrote the BVH importer and exporter.
The best way is to go into pose mode with your existing armature and use constraints to make your armature's bones track to the empties, this can be tricky but has good results in the long run.
- Cam
scourage
Posted: Wed Aug 11, 2004 4:47 am
Ideasman,
I had used your script to create one that makes an armature and animates it instead of empties. However, I don't have it quite right. If you have time, would you mind taking a look and help me find the bugs? Thanks for your time.
Cheers,
Bob
http://bane.servebeer.com/programming/blender
PS. Good work with the renderfarm script. I can't wait to try it out.
_________________
Halfway down the trail to hell....
ideasman
Posted: Wed Aug 11, 2004 7:16 am
BVH rotations are a megga pain- it could be todo with order you apply the rotations in (BVH isnt like blender)
scourage
Posted: Wed Aug 11, 2004 10:42 am
ok, I'll look at the order of the rotations. I hadn't thought of that. Thanks!
Cheers,
Bob
_________________
Monkeyboi
Posted: Sun Aug 22, 2004 11:19 pm
I've applied a .bvh motion capture animation to an armature, which looked great, but as soon as I applied my mesh things got horribly wrong. The bones follow the right empties, but they are rotated wrongly along their local z axis. Is there a way to solve this?
My file is here:
http://www.shadeless.dk/files/mocap_boxer.zip
If the Bake command would let me bake Track To constraints I could manually adjust the bone rotations, but it doesn't seem to be possible.
_________________
Website: http://www.shadeless.dk
an-toni
Posted: Tue Oct 26, 2004 1:53 am
any news on this?
scourage
Posted: Tue Nov 02, 2004 7:47 am
The problem that I'm running into with my bvh importer is that when the joints are not all in the same plane, some of bones get a roll induced in them that messes up the animation (usually along the z axis). This roll is a local roll, and when the world roll is applied from the BVH data, it gets all funky. I'm looking at zeroing this roll or adjusting the BVH data so that it's only a local roll, but I've been lazy and haven't done it yet.
Cheers,
Bob
_________________
Jump to:
