proposal, better fk joint rotation
zbgump
Postby zbgump » Tue Oct 05, 2004 1:38 am
Say you have a relatively long joint chain, like a spine. Right now, selecting the root joint and rotating has the same effect as selecting all the joint in the chain and rotating.
I propose that if you have several joints selected in a chain,rotating them will cause each one to rotate individually in the chain. This would allow much easier FK animation of necks and spines.
slikdigit
Postby slikdigit » Tue Oct 05, 2004 6:02 am
don't think this is a good idea, you're violating what parenting is about.
I do what you want all the time, incidentally; you just need to use constraints and control bones (standard practice in rigging)
there's actually many ways to accomplish this right now (Ok, I can think of at least two)
case one:
parent bone
small child target (just a helper)
next bone, not child to either bone.
copy loc constraint, applied to the "next bone" target the small child target. rinse, repeat.
case two:
parent bone
child bone
control bone for child (not child of parent)
apply copy rot constraint from child bone to control bone.
zbgump
Postby zbgump » Tue Oct 05, 2004 8:27 pm
How would this violate parenting? If you individaully rotate joints they maintain their relative position in the hierarchy, all I'm suggesting is the same thing without having to rotate each bone one by one.
You would still be able to rotate parent bones individually without their children rotating if thats what you needed.
solmax
Postby solmax » Tue Oct 05, 2004 10:08 pm
this is actuyll what i'd expect when "indivisual centers" is selected (header). .. but i hardly "miss" such a feature. when it comes to spines and such, i rely more on tricky setups with constraints, or now with the new features, on the hooks and path-deform.
zbgump
Postby zbgump » Tue Oct 05, 2004 10:33 pm
I think thats the problem! :) Tricky setups.
The way I'm suggesting is the way Maya handles bone rotations; not sure about other packages.
The new hooks are cool, I actually used them recently for the weekend animtion challenge over at elysiun. It helped me to keep my characers legs from collapsing as her leg kicks up high; impossible with smooth skinning alone.
slikdigit
Postby slikdigit » Wed Oct 06, 2004 12:26 am
they're not that tricky- seriously
zbgump
Postby zbgump » Wed Oct 06, 2004 12:33 am
slikdigit wrote:they're not that tricky- seriously
True. I understand their are work-arounds, and theirs a way to do anything if you know what you're doing. I'm just proposing this as a posibility for the future; what I'm propsing seems more intuitive then having to rig up a bunch of constraints, at least to me.
I have no idea how much work this would be, maybe it would require that the entire armature system be re-written! If that was the case then forget it, its not that important. If it is possible, I think it should be considered.
slikdigit
Postby slikdigit » Wed Oct 06, 2004 2:18 am
well, the fact is the constraint system is a current interface to do what you want. It could be easier- for instance, a constraint that translated the "child" to the "parent"'s tip would get rid of the need for a third bone.
I actually prefer the rotate like method- it allows for a clean split between "skinable" geometry bones and control bones, at least , I like it in the spine example- but there are other uses for this.
Other interfaces would be multiple bone types, more options on fk chains (changing the default behaviour would break current rigs), etc. But these things are harder to add than constraints, and should be done with an eye to how the total system will behave.
zbgump
Postby zbgump » Wed Oct 06, 2004 2:48 am
case one:
parent bone
case two:
parent bone
child bone
I'm interested in the method you've outlined here, but I think I may be setting them up wrong. When I set up bones in these 2 methods, what I get is a child bone that stays attatched to the parent but does not rotate as the parent rotates.
Heres an image so I know we're both thinking of the same thing.
The left armature is in the default state, the middle armature has it's root rotated 10 degrees, and the right most armature has each bone individually rotated 10 degrees. The right most one is the system I'm looking for, so I can freely rotate the spine as a whole.
Is this possible with the examples you gave?
slikdigit
Postby slikdigit » Wed Oct 06, 2004 4:50 am
you mean, you don't want each bone to rotate individually, you want them to rotate exactly the same amout? interesting. Not sure how this will get a natural spine, but let me know if that's what you mean
you can do what you want- might get a little intricate- but it is a setup I'm unfamiliar with.
Of course, you might be asking about the spline IK idea, in which case there is a thread about this somewhere in this forum.
zbgump
Postby zbgump » Wed Oct 06, 2004 4:59 am
Yeah , each one rotates individually. This is not good for a true anatomically correct creature, but it should suffice for cartoonish characters.
If you can think of a way to set that up, I would definitely appreciate it :)
thanks
solmax
Postby solmax » Wed Oct 06, 2004 9:35 am
wait until path deform for bones comes. i heard it's in the pipeline. this will solve all your spine problems AND will let you feel a bit more like having XSI power under your fingertips ;)
slikdigit
Postby slikdigit » Thu Oct 07, 2004 1:30 am
yeah zbgump, that's a bit more of an intricate setup, harder to do. How do you want to control it? master control bone, that sends it's rotation to the childeren? or do you want to move a target IK style, and have the chain try to follow with this constraint?
I've never seen a spine rigged this way btw. Live and learn I guess.
Oh yeah, path deform for bones should be the ticket I think.
zbgump
Postby zbgump » Thu Oct 07, 2004 1:35 am
Tell you the truth, I set up my current characters spine with the first suggestion you gave, and it works pretty good.
Don't worry about it, I like your way better :)
Zarf
Postby Zarf » Mon Oct 18, 2004 4:16 pm
solmax wrote:this is actuyll what i'd expect when "indivisual centers" is selected (header). .. but i hardly "miss" such a feature. when it comes to spines and such, i rely more on tricky setups with constraints, or now with the new features, on the hooks and path-deform.
The problem is that the feature that was asked for was a manipulation tool that actually changes the bones rotation data. Constraints on the other hand only change the objects matrix but leave it's location and rotation data alone. I have wanted this feature for a long time, as it is extremely usefull in several high end packages I have used.
Also we need a inverse kinemantics manipulation mode similar to cinema4d or hoow animation masters bones work. Once again this is not the same as a constraint at all. You just select a bone in a chain and manipulate it with IK and it modifies the actual rotation data so you can set FK keys. This works really well for arms and personally I try to use FK keying as much as possible in other apps like Motionbuilder. The only IK constraint I use most of the time is the floor constraint, which is nothing like blenders IK constraint.
With better FK and IK *posing* tools in blender we could add 'pose strips' to the nla system that key a whole skeletons pose at once without constraints or individual bone channels. The pose track could have an option for 'auto ik'; when a joint does not move between poses the limb it belongs to is an ik chain for that frame range. Everything else is fk with nice arcing motions. This is how apps like animanium work and I think it's a wonderfull way of animating that is clean and hassle free. Of course it should be possible to blend pose tracks with action tracks and constraint tracks if the user wanted to.
Cheers,
Zarf
Return to “Animation”
Users browsing this forum: Bing [Bot] and 0 guests
