Previous Thread  Next Thread
chat icon GUI not working in XP (may just be me though)
blacktarantula
Posted: Wed Nov 20, 2002 10:28 pm
Well unfortunately I can't get my display of blender right. I have ATI official drivers for an ATI Rage Pro 3d graphics card and Windows XP Corporate, but it seems all icons are black so I can't see what I'm doing. It worked before but the latest version doesn't and changing the compatibility options in XP don't change anything Confused ... I have a screenshot and if its useful I'll put it online on my website (which isn't actually about Blender but has 100 meg space none-the-less ...
If you can help I'd be most grateful and well done for getting it free!!!
Thanks
ASH
Da BLack Tarantula
Pablosbrain
Posted: Wed Nov 20, 2002 10:41 pm
I know with my new ATI 9700pro I have to have the AntiAliasing and Bilinear Filtering turned to "Application Preference" on the open gl tab of my driver settings for blender buttons and menus to show up properly. check any settings like that...
blacktarantula
Posted: Wed Nov 20, 2002 11:12 pm
Well since I can't afford (and don't yet need in most cases) another computer I have an old RAGE PRO TURBO AGP 2X on this one and since I never change anything setting I can't find where options like you said are..... Sad
Any help you can give?
Thanks
ASH
Pablosbrain
Posted: Wed Nov 20, 2002 11:18 pm
Another setting to try is to switch back and forth from 16bit/24bit/32bit color settings and see if one of those helps... I know some have mentioned over at elYsiun.com that the color depth affects blender.
blacktarantula
Posted: Thu Nov 21, 2002 8:45 pm
I used to think I was good at PC's (which Iam compared to most people that I know) but I can't even find the damned options to get this to work!!!
Crying or Very sad
Its really annoying though I know there must be an easy way - I just can't find the options!
ASH
Eric
Posted: Thu Nov 21, 2002 9:54 pm
I'm sorry to dissapoint you but I wouldn't call it PC-knowledge to know where to look in the windows gui. You won't learn in any way how peecee's work by fiddling in a gui, and especially not windows.
blacktarantula
Posted: Thu Nov 21, 2002 10:00 pm
you obviously don't know what I am talking about - I AM GOOD AT COMPUTING. I CAN USE BLENDER.
I CANNOT FIND A NON-EXISTANT FUNCTION ON XP.
I've been using PC's since before people even knew windows and know how to do a lot, maybe not as much as those anoraks but who gives a ?
All I am saying is I found a problem and would like some help being willing to take feedback (unlike some who spend their time disrupting valid posts)
blacktarantula
Posted: Thu Nov 21, 2002 10:02 pm
Also changing from 32 to 16 etc doesn't seem to change it, pablosbrain
Eric
Posted: Thu Nov 21, 2002 10:43 pm
I'm sorry. I'm just not in the right mood of being myself right now.
Pablosbrain
Posted: Thu Nov 21, 2002 10:53 pm
Right click on your desktop and choose "properties" from the small options popup that displays. Then under the "settings" tab there should be a color depth or colors setting.. Try changing that back to 16bit from 32 or viceversa....
blacktarantula
Posted: Thu Nov 21, 2002 10:57 pm
hmm///
anyway back to the matter at hand:
does anyone have anything valid that they can help me and anyone else with this problem with and also is it known whether who is left to update blender creator whether this ^bug^ (so to speak) will be fixed in the newest release 2.2x and when?
Thanks
ASH
Da BLack Tarantula
blacktarantula
Posted: Fri Nov 22, 2002 3:52 pm
I did try the settings there before you -explained- as I know where they are Wink and they made no difference, neither the [depth] nor the resolution nor any other setting I could find, also nothing in the compatibility window in properties for blender worked to help....
Crying or Very sad
Pablosbrain
Posted: Fri Nov 22, 2002 5:28 pm
Those are all the suggestions I can think off... you might try searching through the forum at elYsiun.com for more suggestions.. I know others have have this problem before.
Sorry it didn't help.
blacktarantula
Posted: Fri Nov 22, 2002 6:57 pm
Thats OK, I can kinda use it but can't do anything much than what I know by heart - no extra bits and pieces then Wink but I just got a dreamcast (long story) so that'll be taking over blender's spot for awhile, probably only until next week....I did try elYsiun's forum but it didn't work Confused but I'll try again another time. Thanks anyway
browman
Posted: Fri Nov 22, 2002 10:26 pm
I had a similar problem on my machine at work, as soon as I rolled over a panel, all the buttons would go blank until I rolled over them again. It was a video driver issue in the end.
That was running XP (although same problem on 2K as well). It was a Dell machine with a 'Dell'ified Diamond Viper V770, so nothing particularly special.
In XP i found the troubleshooting tab on Control Panel/Display/Settings/Advanced did the trick, no reboots required or anything. I just needed to turn it down to one step up from the "No accelleration setting". Unfortunately, with no acceleration, things can get very sluggish with all but the simplest scenes, but it's liveable.
I wasn't being hard enough on it before, and it took me ages to accept that I needed to turn it down that much.
Other than that, ensure you have the latest video drivers.
Goto page 1, 2  Next
Jump to:
