Posted: Fri Dec 06, 2002 11:35 am
Does anyone knows how to render a scene with an effect of depth of field, that is, objects that would be away from the camera would be out of focus. I tried to use the Field button, but the effect was not noticeble. Thanks if anyone can help me.
Posted: Fri Dec 06, 2002 1:41 pm
Hi
Field is not the way to do it.
Try a sequence plugin from
http://www-users.cs.umn.edu/~mein/blender/plugins/
cheers
Posted: Fri Dec 06, 2002 2:01 pm
t_revs, thanks for the tip
Posted: Fri Dec 06, 2002 2:49 pm
Hi t_revs, i have downloaded the plugins, both the source and precompiled for windows, but how do i use them. Do i unpack the source to the blender plugins directory and the precompiled dll to the windows directory? Can you help me?
Thanks
Posted: Fri Dec 06, 2002 8:58 pm
Take a look at this tutorial from Malefico's site:
http://mysite.iptic.com/malefico3d/tutor/dof-en.html_________________
Caronte.
http://www.nicodigital.com
Posted: Fri Dec 06, 2002 9:35 pm
Thanks Caronte for the tip, well i have another question, how do i make the camera track the empty (focus point), i tried parenting but it didn't work.
Posted: Fri Dec 06, 2002 9:48 pm
You can do begginer questions like this one in the elysiun forum
http://www.elysiun.com
This site is mainly for development.
To track the camera (or anything) to another object, select the camera press SHIFT, select the target and press CTRL+T.
May be do you need to remove rotation of the camera:
Select the camera and press ALT+R
In the animation button's window F7 you can find some X Y Z button's to diferent types of tracking.
See you.
_________________
Caronte.
Posted: Fri Dec 06, 2002 9:59 pm
Again thanks Caronte for the tip, and i will try elysion site for more info for beginners.
