Posted: Wed Dec 04, 2002 6:06 am
... for dumb how-do-I questions?
I would like to know if there is a way to scale an objects non-uniformally eg. I'm modelling a wood molding cut at a diagonal at one end. Fastest easiest way was to rotate one end by 45 degrees, then scale it larger in 2 directions. But not the third; I don't want a thicker board at one end. This seems really basic, so I'd be surprised if Blender can't do this, but hell if I can find how ....
_________________
Chris Barry
Posted: Wed Dec 04, 2002 2:37 pm
| 23yrold3yrold wrote: |
| ... for dumb how-do-I questions? |
erm.. nope... the Elysiun forums (www.elysiun.com) are, but I'll let you off!
Do you have a middle mouse button!?
If you start to scale an object, move your mouse in the direction you want to scale and then press the middle mouse button. If you move your mouse again, you'll see that the scale is limited to that axis.
Hope this helps!
As a side note, this method works with moving objects too!
Posted: Wed Dec 04, 2002 4:10 pm
Arg .... no middle mouse button. Any other way?
_________________
Chris Barry
Posted: Wed Dec 04, 2002 5:17 pm
alt left mouse button should be enabled by default if its not
you need to goto the i window and make sure the 2-mouse button
is clicked.
Posted: Wed Dec 04, 2002 6:49 pm
That did it
Thanks.
I'll remember to go to Elysiun with my newb questions from now on too
_________________
Chris Barry
Posted: Wed Dec 18, 2002 7:36 pm
Elysiun.com?? This is my first time on the new blender website. I haven't used it in a year or so and I'm trying to figure out the site now. Are we supposed to use another website for some questions?
Sincerely,
Yasoo
