Previous Thread  Next Thread
chat icon Question about compatability
blazer003
Posted: Mon Aug 15, 2005 12:10 am
I'm just starting to rig my Yoda model that some may have seen, in Blender 2.37. I was wondering if the new animation and armature system overhaul will be backward compatable. In other words, should I wait for the next release before I rig? Usually Blender is very good with backwards compatability, but this sounds like a massive recode of armatures, so I want to make sure. Thanks.
Matt
Bagration
Posted: Mon Aug 15, 2005 10:33 am
It will be backwards compatible, but older versions won't be able to open new files correctly (not forwards compatible, if that's a word). That's probably why they changed the version number to 2.40. I think there will be only small issues though; when I opened a scene created in a testing build in 2.37a, everything was upside down for example. Smile
Why don't you just start rigging with a testing build? They aren't that instable, just save often and have your model in a separate (2.37a) file.
blazer003
Posted: Thu Aug 18, 2005 7:47 pm
Sounds good, except the sub surfs weren't working in the test build. Not that that is a really big deal, but you can't see exactly what it looks like. I don't know if that should be submitted as a bug, or where it should be submitted.
LetterRip
Posted: Fri Aug 19, 2005 3:17 am
subsurf is now a modifier and you need to goto the modifier stack to enable and disable it, I haven't had any problems with it not working, but it is different and a little confusing to try and find at first.
LetterRip
Jump to:
