problem when compiling the latest cvs.
Pol
Postby Pol » Sun Dec 22, 2002 7:44 pm
Hello all =)
I get some problem (this is the second time I get that error when compiling the cvs) with the cvs look the output here:
make[3]: Entering directory `/home/pol/blender/source'
/bin/sh ../libtool --mode=link gcc -g -O2 -o libblender_source.la -rpath /usr/local/lib -L/usr/lib/python2.2/config -L/usr/X11R6/lib -L/usr/X11R6/lib -lpython2.2 creator/libblender_creator.la blender/libblender_blender.la kernel/libblender_kernel.la -lXxf86dga -lGLU -lGL -lSDL -lutil -lm -ljpeg -lpng -lcrypto -lssl -lpthread -ldl -lstdc++ -lz
rm -fr .libs/libblender_source.la .libs/libblender_source.* .libs/libblender_source.*
gcc -shared -Wl,--whole-archive creator/.libs/libblender_creator.al blender/.libs/libblender_blender.al kernel/.libs/libblender_kernel.al -Wl,--no-whole-archive -Wl,--rpath -Wl,/opt/kde/lib -Wl,--rpath -Wl,/usr/local/lib -Wl,--rpath -Wl,/opt/kde/lib -Wl,--rpath -Wl,/usr/local/lib -L/usr/lib/python2.2/config -L/usr/X11R6/lib creator/.libs/libblender_creator.al -lm -L/opt/kde/lib -ldl -L/usr/lib -lm -ldl -lm -lpthread -ldl -lm -lm -lm -L/usr/i386-slackware-linux/bin -L/usr/i386-slackware-linux/lib -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s blender/.libs/libblender_blender.al -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lpython2.2 -ldl -lm -lpthread -lm -ldl -lpthread -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lpthread -lm -ldl -lm -ldl -ldl -lpthread -lm -lm -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lm -ldl -lpthread -lm -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s kernel/.libs/libblender_kernel.al -lm -ldl /opt/kde/lib/libartsc.so /usr/lib/libesd.so /usr/lib/libaudiofile.so -lm -lX11 -lXext -ldl -lm -lpthread -ldl -lm -lm -lm -lgcc_s -lc -lgcc_s -lm -lgcc_s -lc -lgcc_s -lXxf86dga -lGLU -lGL /usr/local/lib/libSDL.so -lutil -lm -ljpeg -lpng -lcrypto -lssl -lpthread -ldl /usr/lib/libstdc++.so -lz -Wl,-soname -Wl,libblender_source.so.0 -o .libs/libblender_source.so.0.0.0
collect2: ld terminated with signal 11 [Segmentation fault], core dumped
make[3]: *** [libblender_source.la] Erreur 1
make[3]: Leaving directory `/home/pol/blender/source'
make[2]: *** [all-recursive] Erreur 1
make[2]: Leaving directory `/home/pol/blender/source'
make[1]: *** [all-recursive] Erreur 1
make[1]: Leaving directory `/home/pol/blender'
make: *** [all] Erreur 2
[19:36:40][pol@213.177.154.32:/home/pol/blender]$
Someone can help ?
Thanks.
segg
Re: problem when compiling the latest cvs.
Postby segg » Mon Dec 23, 2002 4:27 am
Pol wrote:Hello all =)
Someone can help ?
Thanks.
Seconfd try
well i really hate this little box
Solution create more swap space
Create first a file with 200MBytes
$ dd if=/dev/zero of=/mnt/swap bs=1024 count=200K
$ mkswap /mnt/swap
$ swapon /mnt/swap
check that it is OK
$cat /proc/swaps
have Merry Chrismas
Pol
Postby Pol » Mon Dec 23, 2002 9:32 am
it still does not work.
[09:31:39][pol@213.177.154.32:/home/pol/blender]$ cat /proc/swaps
Filename Type Size Used Priority
/dev/hda3 partition 979956 0 -1
/mnt/swap file 204792 0 -2
[09:32:38][pol@213.177.154.32:/home/pol/blender]$ uname -a
Linux slack 2.4.20 #2 SMP lun dc 2 17:25:07 CET 2002 i686 unknown
[09:32:43][pol@213.177.154.32:/home/pol/blender]$
any idea ?
Have a merry christmas too =)
pallem
RE:problem when compiling the latest cvs.
Postby pallem » Mon Dec 23, 2002 9:26 pm
I HATE seg faults.
A silly question, is this the first time you have compiled CVS blender or any other large project. You gave no hint in your post, although your profile suggests you may have.
And now some sillier questions. Has the temperature changed (hotter, colder [don't laugh, it happens!]), does the system have air filters (plugged), are fans operating, can you access system temperatures (is it hot), has hardware changed, has any software been added/changed?
Sometimes a marginal system can run for years with no problems at all, until you run some software that really beats on it, then it hiccups.
I don't know if you know what a Seg Fault is, but it simply means that the processor is executing code or accessing data that does not belong to the task that it is running (bad pointers). The processor could also be executing random garbage (drove of the edge of the world).
Hope this helps,
pallem
segg
Postby segg » Thu Dec 26, 2002 3:40 am
Pol wrote:it still does not work.
$ cat /proc/swaps
$ uname -a
any idea ?
harddisk space
$ df
usually gcc will used /tmp directory has for temporary file, make sure you have enough space in that directory, clean it up
try also if this work
$ gcc -shared -Wl,--whole-archive creator/.libs/libblender_creator.al blender/.libs/libblender_blender.al kernel/.libs/libblender_kernel.al -Wl,--no-whole-archive -lstdc++ -Wl,-soname -Wl,libtata.so.0 -o libtata.so.0.0.0
and do not forget to remove it
$ rm libtata.so.0.0.0
Pol
Postby Pol » Thu Dec 26, 2002 1:52 pm
Thanks for the help but I still get problem.
[13:47:39][pol@213.177.154.32:/home/pol/blender/source]$ df
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/hda1 37836272 31106456 4776716 87% /
/dev/hda2 28834744 12354956 15015064 46% /mnt/hd/hda2
[13:48:06][pol@213.177.154.32:/home/pol/blender/source]$
[13:48:17][pol@213.177.154.32:/home/pol/blender/source]$ cat /proc/swaps
[13:48:21][pol@213.177.154.32:/home/pol/blender/source]$
[13:48:21][pol@213.177.154.32:/home/pol/blender/source]$ free
total used free shared buffers cached
Mem: 773924 570484 203440 0 58408 346492
-/+ buffers/cache: 165584 608340
Swap: 979956 0 979956
[13:48:32][pol@213.177.154.32:/home/pol/blender/source]$
[13:49:29][root@213.177.154.32:/home/pol/blender/source]# lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT82C693A/694x [Apollo PRO133x] (rev c4)
00:01.0 PCI bridge: VIA Technologies, Inc. VT82C598/694x [Apollo MVP3/Pro133x AGP]
00:07.0 ISA bridge: VIA Technologies, Inc. VT82C686 [Apollo Super South] (rev 40)
00:07.1 IDE interface: VIA Technologies, Inc. VT82C586B PIPC Bus Master IDE (rev 06)
00:07.2 USB Controller: VIA Technologies, Inc. USB (rev 16)
00:07.3 USB Controller: VIA Technologies, Inc. USB (rev 16)
00:07.4 Host bridge: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI] (rev 40)
00:0e.0 Ethernet controller: 3Com Corporation 3c900 10BaseT [Boomerang]
00:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
00:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
00:11.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 07)
00:11.1 Input device controller: Creative Labs SB Live! MIDI/Game Port (rev 07)
01:00.0 VGA compatible controller: nVidia Corporation NV20 [GeForce3 Ti200] (rev a3)
[13:49:31][root@213.177.154.32:/home/pol/blender/source]#
[13:49:31][root@213.177.154.32:/home/pol/blender/source]# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 8
model name : Pentium III (Coppermine)
stepping : 10
cpu MHz : 1000.032
cache size : 256 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 mmx fxsr sse
bogomips : 1992.29
processor : 1
cpu family : 6
model : 8
stepping : 10
cpu MHz : 1000.032
cache size : 256 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
bogomips : 1998.84
[13:49:50][root@213.177.154.32:/home/pol/blender/source]#
And I still get the error ...
make[1]: Entering directory `/home/pol/blender/source'
make[1]: *** [libblender_source.la] Erreur 1
make[1]: Leaving directory `/home/pol/blender/source'
make: *** [all-recursive] Erreur 1
[13:50:31][root@213.177.154.32:/home/pol/blender/source]#
I also tried your trick in your past message:
[13:50:56][pol@213.177.154.32:/home/pol/blender/source]$ gcc -shared -Wl,--whole-archive creator/.libs/libblender_creator.al blender/.libs/libblender_blender.al kernel/.libs/libblender_kernel.al -Wl,--no-whole-archive -lstdc++ -Wl,-soname -Wl,libtata.so.0 -o libtata.so.0.0.0
[13:51:01][pol@213.177.154.32:/home/pol/blender/source]$ ls libtata.so.0.0.0
libtata.so.0.0.0*
[13:51:07][pol@213.177.154.32:/home/pol/blender/source]$ ls -l libtata.so.0.0.0
-rwxr-xr-x 1 pol users 8569055 déc 26 13:51 libtata.so.0.0.0*
[13:51:11][pol@213.177.154.32:/home/pol/blender/source]$
I use Slackware 9.0, gcc 3.2.1, 2 CPU,... I shouldn't have any problem ...
Thanks for any suggestion.
-pol-
kattkieru
Postby kattkieru » Thu Dec 26, 2002 4:47 pm
It looks like something strange is going on in your build; there're a bunch of flags that are repeated...
How did you start your build process? Did you just download the CVS tree and hit make, or did you use the automake system beforehand? Also, see what happens when you compile blender using static libraries. I think you type ./configure --enable-blenderstatic --disable-shared, then re-run make.
Pol
Postby Pol » Mon Dec 30, 2002 6:19 pm
kattkieru wrote:It looks like something strange is going on in your build; there're a bunch of flags that are repeated...
I tried everything ... but I still get the same error .... what can I do ?
Thanks.
-pol-
Return to “Coding Blender”
