Whats with -lGLU and makesdna??
VelikM
Postby VelikM » Tue Dec 24, 2002 6:05 am
MakesDna is the only place that -lGLU appears that it's not found.
gcc -g -O2 -o makesdna makesdna-makesdna.o ../../../../intern/guardedalloc/.libs/libblender_guardedalloc.al -lGLU -lGL -lm -ljpeg -lpng -lcrypto -lssl -lpthread -ldl -lstdc++ -lz
ld: can't locate file for: -lGLU
*** Error code 1
./configure is finding it: checking for gluGetString in -lGLU... yes
Any ideas?
kobyl
satisfying -lGLU
Postby kobyl » Wed Dec 25, 2002 11:34 pm
I suggest a link from /usr/lib/libGLU.so to where your libGLU.so is (probably /usr/X11R6/lib/libGLU.so).
VelikM
Re: satisfying -lGLU
Postby VelikM » Thu Dec 26, 2002 6:36 am
kobyl wrote:I suggest a link from /usr/lib/libGLU.so to where your libGLU.so is (probably /usr/X11R6/lib/libGLU.so).
I'm running OS X, and I do have X11 installed and libGLU.a is installed there. I ln -s libGLU.a to /usr/lib already so ./configure could find it (checking for gluGetString in -lGLU... yes) all the other places -lGLU is needed it's found with no errors or warnings, just in makesdna is there a problem. Is there something about makesdna the requires libGLU.so that libGLU.a won't fill the need for? Since libGLU.a seems to fill the rest of the requirements.
sgefant
Postby sgefant » Thu Dec 26, 2002 11:59 am
Actually, makesdna doesn't need "-lGLU -lGL -lm -ljpeg -lpng -lcrypto -lssl -lpthread -ldl -lstdc++ -lz". Somehow autoconf put those there....
Could you edit $builddir/source/blender/makesdna/intern/Makefile and remove any references to them and see if it compiles?
sgefant
VelikM
Postby VelikM » Thu Dec 26, 2002 11:49 pm
I commented this line out in makesdna/intern/Makefile:
# LIBS = -lGLU -lGL -lm -ljpeg -lpng -lcrypto -lssl -lpthread -ldl -lstdc++ -lz
Now the error occures here after makesdna is built:
This is an improvement, at least makesdna is building. :)
EDIT:
I use the tcsh shell, I've added the full paths to .tcshrc, .cshrc, .shrc and /sw/bin/init.csh, and init.sh so there should be know problems finding anything. 8)
Return to “Coding Blender”
