Cut Scene ?
abstract
Cut Scene ?
Postby abstract » Wed Sep 28, 2005 5:54 pm
hey !
i have a scene with 1500 frames and need to cut it in seperate scenes.
like from frame 250-300 and 450-600 ... end make a new scene out of it
how does it work !??
Thanxx
joeri
Postby joeri » Thu Sep 29, 2005 9:37 am
Create new scene in the pulldown near SCE: and select "Linked data"
This will create a new scene with it's own possible render settings but will have all the objects linked from your main scene. You can now select another camera or even create a new one in this scene.
If you want to render this in one go then you need another seq_edit scene and add the new scenes as a strip in the seq_editor.
abstract
Postby abstract » Thu Sep 29, 2005 2:47 pm
thanxx good idea !
is there a cool way to delete the unneeded stuff in the scene.
e.g. i make a new scene and want now only the animations between frame 200-300. do i have to delete the other aimations by hand or is there a simplier way to cut just the needed sequence out ?
P.S. next time i will start with multiple scenes aarrrgghh :oops:
joeri
Postby joeri » Sun Oct 02, 2005 1:23 pm
Why delete them? They don't take up (much) extra harddisk space.
If you've got linked objects then everything you do will be done to them in every scene. So no, don't remove anymations from objects. You can savely remove the objects out of your scene (they will stay in the original scene).
ctrl-L is your friend, with this you can link (instance) objects to other scene's and with ctrl-U you can single-user them (make a copy out of the instance that can be altered without altering the object you linked it from).
Return to “Animation”
