Previous Thread  Next Thread
chat icon [UPDATE sculpt mode]Windows 20060627
lguillaume
Posted: Wed Jun 14, 2006 9:26 am
Hello, now we have access of SoC cvs.
I made a compilation of the Sculpt Mode projects : downloads
To enable Sculpt mode, in header view 3d, you have to change to sculpt mode in the pulldown menu where there are all other mode : edit, object, paint, ...
After go to Edit panel (F9) and you have a new panel.
For multires, you have to create one in Edit mesh panel (F9Key) and to press the button create after multires, a new panel is created called multires with a button Add level, pres it and you have created multiresolution for the mesh.
BUG Corrected :
When you have sculpted on mesh and add a level, the sculpt we make has not keeped, now it's corrected.
Attention : don't doing undo for sculpt, undo works ok, but when sculpting after undo, blender crash.
ajuss
Posted: Wed Jun 14, 2006 10:15 am
it gave me this error
Ordinal not found
The ordinal 63 not be located in the dynamic link library zlib.dll
lguillaume
Posted: Wed Jun 14, 2006 10:42 am
ajuss wrote:
Ordinal not found
Try this DLL
ajuss
Posted: Wed Jun 14, 2006 12:28 pm
that helped
thank you very much!
pildanovak
Posted: Wed Jun 14, 2006 12:41 pm
very nice, crashes often, but works nice. Is not very fast, but i think maybe it's the same problem as other people scripting sculpt tools had(redraw of Blender window). It's great to play with sharpcontruct inside of Blender...
env
Posted: Wed Jun 14, 2006 7:02 pm
Works nicely for me, it's quite fast and stable. Thanks for the build.
kakapo
Posted: Wed Jun 14, 2006 8:40 pm
wow, very cool already! Smile
i hope there will also be tablet pressure sensitivity support? and i am looking forward to the multi resolution feature.
infinder
Posted: Fri Jun 16, 2006 8:19 am
Hey, lguillaume!
How did you compiled sculpt mode from soc cvs?
Is it posiple with cygwin?
What kind of commands should i give to download what is necessary for compiling soc cvs? Idea Question
Stamatis
lguillaume
Posted: Fri Jun 16, 2006 10:20 am
infinder wrote:
Hey, lguillaume!
Stamatis
Hi to download cvs I use http://www.tortoisecvs.org/
After you have this program and reboot your computer, create a directory, click with rigth button on it, normally you have an entry called CVS Checkout... click on it.
A dialog box opens, on CVSROOT: past :pserver:anonymous@cvs.blender.org:/cvsroot/soc-2006
On module past : soc-blender
After go to Revision tab on top where there is Branch or tag click on Choose branch or tag and type nicholasbishop where there is HEAD
Normally the CVS downloads, after this, you just have to right click on the directory where the cvs is in (the directory have a green icon) and do CVS Update.
For Cygwin I don't know if you can compile this project on it, I use Scons + MSVC
tischbein3
Posted: Sat Jun 17, 2006 1:42 pm
wow, this was fast.....
I'm maybe wrong, but it seems the smooth brush does have problems on
uv sphere pole points (points connected to more than 4 polys ?)
already a really nice tool.
Kaptain Kubrick
Posted: Sun Jun 18, 2006 12:56 am
Would anyone be able to post a screen shot?
tischbein3
Posted: Sun Jun 18, 2006 6:56 am
ok, command back, seems a general problem with smoothing brush and polys (non subpatched objects).
Justa few questions:
Will you also add the grab brush ?
Is there a plan to integrate it into blenders edit panel after things go well ?
again thank you!
ZanQdo
Posted: Mon Jun 26, 2006 2:13 am
Please update! multiresolution is ready for testing now Shocked
_________________
Smile Hosting for your test builds:
GraphicAll.org
pildanovak
Posted: Mon Jun 26, 2006 12:56 pm
works nice here, crashes often, but reeeaaalllyyy nice zbrush
infinder
Posted: Tue Jun 27, 2006 10:46 am
pildanovak or anybody else, could you please explain about the use and usage of this multiresolution thing in sculpting procedure?
Stamatis
Goto page 1, 2  Next
Jump to:
