GUI problems
Carl
GUI problems
Post by Carl » Wed Mar 19, 2003 8:04 am
Hi!
I am completely new to Blender, though I have used a few other 3D applications in the past.
When installing everything looked fine, but when running the program, all button icons are gone, and in their place is just a black rectangle. I have no clue as to why it is like this. It worked on another computer when I tried it. Also tried un/re-installing without success.
My computer: DELL laptop, PII Celeron 466 MHz, 192 MB RAM. Graphics: 8 MB.
Does anyone know how I can fix this?
H@dj
Post by H@dj » Wed Mar 19, 2003 9:19 am
HiCarl,
your problems more then likely are your graphics card.
your card has to be openGL compatible,,and if it is then try,
(assuming your using windows) slowing downthe hardware acceleration:
right click your desktop and goto,
propertys>settings>advanced>proformance
and turn the slider down about halfway(2nd notch)
hope this helps,
dale
Carl
Post by Carl » Wed Mar 19, 2003 11:44 am
Thanks!
But... hmm... can't seem to find it. Maybe because I use Win 2k? I know I have seen that setting before, but that might have been on Win 98 or so....
But if you think it might be OpenGL that is the problem, maybe I should try to upgrade my display drivers or something. I'll have to try that.
My video info (from AIDA):
--------[ AIDA32 (c) 1995-2003 Unlimited Possibilities ]----------------------------------------------------------------
Version AIDA32 v3.30
Author fiery@aida32.hu
Homepage http://www.aida32.hu
Report Type Quick Report
Computer **********
Generator **********
Operating System Microsoft Windows 2000 Professional 5.0.2195 (Win2k Retail)
Date 2003-03-19
Time 11:42
--------[ Windows Video ]-----------------------------------------------------------------------------------------------
[ ATI RAGE MOBILITY-M1 AGP2X (English) ]
Video Adapter Properties:
Device Description ATI RAGE MOBILITY-M1 AGP2X (English)
Adapter String 1002-4C4D-64-1028-00AA
BIOS String SDRAM BIOS 4.244T(MERCURY)
Chip Type ATI RAGE Mobility P/M AGP 2X (A21/2)
DAC Type ATI Internal DAC
Installed Drivers ati2drab
Memory Size 8 MB
Video Adapter Manufacturer:
Company Name ATI Technologies Inc.
Product Information http://www.ati.com/products/builtdesktoppc.html
Driver Download http://www.ati.com/support/driver.html
Regards
Carl
matt_e
Post by matt_e » Wed Mar 19, 2003 12:05 pm
Have you got fullscreen anti-aliasing turned on? This has been known to cause problems with Blender.
phase
Post by phase » Wed Mar 19, 2003 1:17 pm
Try changing your desktop settings to 32 bit colors.
I also work on a laptop with an ATI M1 graphics card
and Blender performs excellent with the 32 bit setting.
Rob
IoN_PuLse
Post by IoN_PuLse » Wed Mar 19, 2003 7:59 pm
Yes check the drivers, I am 99.9999% that is the cause of your issue. I have used Blender on win2k flawlessly in the past. I would check into newer drivers or fiddle with driver settings.
endi
Post by endi » Thu Mar 20, 2003 9:49 am
I have same problem with my laptop (S3 Savage 8M). When I turned off the "mouse shadow" option in win2K, the problem solved!
Carl
Post by Carl » Fri Mar 21, 2003 8:25 am
Hi again!
Thanks for all your replies! Wow, you are REALLY trying to help me out! What a great bunch of people you are! :)
Though, unfortunately, I have tested all of above (Upgraded driver, lowered hardware acceleration, 32-bit colors (already had that on), turned off mouse shadow). But no change in Blender... :/ Ah well.. I suppose my graphics card just is no good with OpenGL...
Thanks again for all your concern!
Regards
Carl
metaphorz
A Rage Mobility Solution
Post by metaphorz » Sat Mar 22, 2003 11:00 pm
Yes, I had this problem as well. Here is the fix that worked for me--
very simple, and no need to mess with the hardware acceleration.
You will have 3 display resolution settings:
Medium: 16 bit
High: 24 bit
Highest 32 bit
Choose 24 Bit and your problems may well disappear. 16 bit
and 32 bit do not work on my rage mobility card (inside a Fujitsu
Lifebook notebook computer).
-pf
Carl
Post by Carl » Mon Mar 24, 2003 7:20 am
Well... what can I say?
THANK YOU!!!!! IT WORKED!!!!
I can't imagine I did not try 24-bit! I tried, 16-bit, 32-bit, different resolutions, different hardware acceleration... the works, but not 24-bit! :) :)
Odd...
But thanks again!!
Hmm... this maybe should be listed in some kind of "Known problems with certain hardware" topic or so.
Best regards
Carl Gustafsson
