One suggestion is where the user can press a macro that allows them to access whole other sets of macros. For example, if some artist made a set of
macros for modeling and a whole set for texturing; they could just press F9 or something, and a Modo style radial menu would pop up showing the macro sets you made.
Another, is a visual scripting tool as used by the Unreal Engine such as Kimset. This would make it easier for Artist with little coding experience to create plug-in's and tools for blender. This would be fairly easy to set up using blenders node system.
Screenshot of Kimset:
http://unrealtechnology.com/media/banne ... ismet2.jpg
My Suggestions for Blender 2.5
One thing that I would like to see in future versions of Blender is Better Material Management. I am a Max User who is starting to do a lot more in Blender and I would really like to see some sort of Material System like the one found in Max. Mainly the ability to have a Material Library that you can use to manage your collection of Materials.
- Site Admin
Re: My Suggestions for Blender 2.5
You'll be pleased to learn, that one of the goals for the event rewrite for Blender 2.5 is having a macro and recording system.anthoni_c wrote:One suggestion is where the user can press a macro that allows them to access whole other sets of macros. For example, if some artist made a set of
Also, with the rewrite, and after, the node system will very likely be extended to make something like "Visual Python" possible, ie. visual scripting.anthoni_c wrote: Another, is a visual scripting tool as used by the Unreal Engine such as Kimset. This would make it easier for Artist with little coding experience to create plug-in's and tools for blender. This would be fairly easy to set up using blenders node system.
/Nathan
I suggest these great implementations...
1)New Object_Manager (outliner) with "Tags" for any function... like Cinema4D!!!
This allow to find any tool istantaneusly under control by a contestual menu (Atribute manager) just only with a click over the"tag" in outliner....
2)Node based programming like Xpresso (Cinema4D): add relationship between objects without programming any code... (math.. boleans... logic... etc.) any parameter of any tool&object should be parametrize by node editor!!
For some examples look at this page
http://library.creativecow.net/articles ... Presso.php
And a GREAT Xpresso site...
http://www.base80.com/
Hi guys
Let's take a look also at this page for other examples of "object manager"--&--"atribute manager" and to take some inspiration from this luxury and EASY interface!!!
http://images.google.it/images?hl=it&q= ... a=N&tab=wi
