Exporting Video to Quicktime Format
Dooble Studios
Post by Dooble Studios »
I just made a video in blender and needed to export it to a quicktime format for youtube. If someone could please help that would be great Thanks!
Dylan
psullie
Post by psullie »
is this an animation or a sequence?
All your options are in the scene tab (F10)
Choose a destination folder from the Output tab,
Choose an appropriate x&y size in the Format Tab
Choose either:
Quicktime in the format tab, select your codec and hit the ANIM button.
You might get better compression and quality with FFMpeg and then select Quicktime in the Video tab that appears.
If is a sequence, same principle just select Do Sequence
Check out the wiki: http://wiki.blender.org/index.php/Doc:Manual, lots of tips here.
Paul
Dooble Studios
Exporting blender to quicktime format
Thanks so much that helped a lot
Dylan
tsgfilmwerks
Post by tsgfilmwerks »
It's a little odd; there used to be (at least in the mac version) an option to encode videos directly as quicktime. Now there's only avi & such. Luckily that's not a big deal to convert, though.
psullie
Post by psullie »
tsg,
I'm using RC3 and have the option to encode directly as quicktime, Video encoding is dependent though on having your own encoders, divx etc but I've never had issues with quicktime (expect the huge files it produces).
Paul
Dooble Studios
tsgfilmwerks wrote:It's a little odd; there used to be (at least in the mac version) an option to encode videos directly as quicktime. Now there's only avi & such. Luckily that's not a big deal to convert, though.
Thanks so much that helped a lot actually. I finally figured it out :D
