Exporting Video to Quicktime Format
I just made a video in blender and needed to export it to a quicktime format for youtube. If someone could please help that would be great Thanks!
Dylan
is this an animation or a sequence?
All your options are in the scene tab (F10)
Choose a destination folder from the Output tab,
Choose an appropriate x&y size in the Format Tab
Choose either:
Quicktime in the format tab, select your codec and hit the ANIM button.
You might get better compression and quality with FFMpeg and then select Quicktime in the Video tab that appears.
If is a sequence, same principle just select Do Sequence
Check out the wiki: http://wiki.blender.org/index.php/Doc:Manual, lots of tips here.
Paul
Choose either:
Paul
