Blender for Windows 7 64 Bit???
beeman
Post by beeman » Sat Nov 07, 2009 5:35 am
I just got my new PC and am getting ready to install Windows 7. I want to install the 64 bit version, but it looks like Blender will not be supported. Any idea as to whether a 64-bit version for Windows is available?
jivanoff
Yes there is a 64 bit and it works fine!
Post by jivanoff » Thu Nov 12, 2009 9:01 pm
I am running the 64 bit version in my Windows 7 64bit, no problems even though there is no installer, just unzip it to a folder and start it from there or drag a shortcut to where ever You want it. Just remember to get the 64 bit version of Python 2.6.x installed properly.
/Jari
Jari Ivanoff
arilds
Blender for Windows 7 - 64 bit
Post by arilds » Fri Nov 20, 2009 3:48 am
Hi Jari,
I tried what you said should work, but when I try to run Blender I get this message:
The application has failed to start because its side-by-side configuration is incorrect.
Python 64 bit installed successfully.
jbrower115
Post by jbrower115 » Thu Dec 03, 2009 9:36 pm
I have the same problem. I'm running Windows 7 64 bit and I have not installed Python. I have been trying to use the 2.49b in 64 bit and it says nothing about W7.
--j
jbrower115
Post by jbrower115 » Thu Dec 03, 2009 9:54 pm
Check this out:
http://www.seangw.com/wordpress/index.p ... incorrect/
and:
http://www.microsoft.com/downloads/en/c ... layLang=en
I put that MS Visual C++ thing on and Blender started right up! Hope this helps.
--j
jbrower115
Post by jbrower115 » Thu Dec 03, 2009 10:05 pm
ok, now I need Python. Where can I find it?
--j
kidb
Post by kidb » Thu Dec 03, 2009 10:11 pm
pBarrelas
Post by pBarrelas » Thu Dec 17, 2009 12:42 am
I've installed it Win7 64 after installed Python and it's running even though I'm a real noob on Blender. :)
