2.29: radiosity render!
Something I wanted to do a long time, finally got some time for it.
It just has been committed to the bf-blender tree.
This is what the new code does:
Using the core routines of the Radiosity tool, each renderface with 'emit material' and each renderface with 'radio material flag' set will be used to itterate to a global illumination solution. Per face with high energy (emit) little images are rendered (hemicubes) which makes up lookup tables to 'shoot' its energy to other faces.
In the end this energy - color - then is directly added to the pixel colors while rendering, Gouraud shaded.
Since it's done with renderfaces, it works for all primitives in Blender.
What is doesn't do yet:
- take into account textured color of faces. Currently it uses the material RGB color for filtering distributed energy.
- do some smart pre-subdividing. I don't know yet if this is useful... Right now it means that you'll have to balance the models yourself, to deliver small faces where you want a high accuracy for shadowing.
- unified render (is at my todo list)
Rendering without lamps:
http://www.blender.org/bf/raptor.jpg
This is obviously the advantage; animated radiosity:
http://www.blender.org/bf/0001_0031.avi
http://www.blender.org/bf/0001_0040.avi
The specular is done by adding Lamps with "no diffuse" option set.
http://www.blender.org/bf/monkey.jpg
Note the subtle color bleeding in the head. Its a nice toy!
http://www.blender.org/bf/0001_0100.avi
Check the chin. This is a clear problem with a model moving close through the hemicubes.
Testfiles:
http://www.blender.org/bf/room.blend
http://www.blender.org/bf/Raptor_radio1.blend
User notes:
- per Material you want to have included in radiosity render: set the 'radio' flag. For newly added Materials it is ON by default now.
- the Ambient slider in Material controls the amount of radiosity color.
- for enabling radiosity rendering, set the F10 "Radio" button.
- the Radiosity buttons now only show the relevant radiosity rendering options. Pressing "collect meshes" will show all buttons again.
- for meshes, the faces who use Radio material always call the 'autosmooth' routine, this to make sure sharp angles (like corners in a room) do not have shared vertices. For some smooth models (like the raptor example) you might increase the standard smoothing angle from 30 to 45 degree.
- While itterating the steps are printed in the console. I'd like to see a better system for it in Blender itself...
- At the end, the amount of 'unshot energy' is printed in the console, this can be used to set a minimum for the Convergence button.
Technical notes:
- I had to expand the renderface and rendervertices for it... shame on me! Faces have one pointer extra, render vertices four floats...
- The size of the hemicubes is now based at the boundbox of the entire scene (0.002 of it). This should be more reliable... to be done
- I fixed a bug in radiosity render, where sometimes backfaces where lit
- the link order for Blender has changed, the libradiosity.a has to be moved after the librender.a (obviously for a new dependency!). Check blender/source/Makefile
- there's a new file: blender/source/radiosity/intern/source/radrender.c
In general:
I'd like everyone to play a bit with this system. It's not easy to get good results with it. A simple "hit and go" isn't there... maybe some good suggestions?
-Ton-
Testfiles:
User notes:
Technical notes:
In general:
-Ton-
Oh, of course we need a binary:
OSX:
http://www.blender.org/bf/blender.app.zip
It's not an official release! I guess others will post some test binaries for other platforms.
OSX:
AAAAAA !!!! your after my own heart... An OSX build as the very first, YaY ! I actually do not have to do building code..ton wrote:Oh, of course we need a binary:
OSX:
^v^ testing .... weeeee
Now just put the new Loop select into blender, red face select, shaded face select mode. And a way to get Face select into edit mode with out haveing to press tab and F so much...and you can start to get people out of haveing to need wings every minute for modeling... ^o^
oh boy,engalicorn wrote:
money_YaY.... only 52 more posts and youll surpass ton on # of posts to the new blender community
Ok the first is just toying with the mesh to see how grooves work..
http://aprilcolo.com/oh/tank/raptor.jpg
this one was a lantern shadow test. ( I found out latter that it needs more mesh to make it do a proper shadow..
http://aprilcolo.com/oh/tank/tonlight.jpg
test two
http://aprilcolo.com/oh/tank/tonlight2.jpg
particule test. They sort of work.. not well...
http://aprilcolo.com/oh/tank/tonlight3.jpg
and here is a spot light test. It workks ! a cone was place over the light mesh. "lampshade"
http://aprilcolo.com/oh/tank/tonspot.jpg
and now it is in his eyes and mouth
http://aprilcolo.com/oh/tank/tonspot2.jpg
What is wrong....
Cel shadeing is not working...for the radio
Particules.
And how do you remove the little light bugger from the render. I tried a invs face all but no go..
YaY Fun ^v^
yes , would be neatton wrote:In fact this system is another 'diffuse shader'. I think I can hack it to make toon shading work for it...
OTH, I can also move the "radio" option to the shaders menu, isn't that a more appropriate menu location?
btw, how do I myself now change the source to able to try this new feature?
Sorry, just got help on #blendersauce , they said bf-blender, stupid me /me slaps his forehead...
and they helped me how to do CVS on bf-blender, seems compiling just fine now
old questions:
Is this a CVS update for BF-Blender, not Tuhopuu2? ...or am I totally wrong?
old questions:
I know how to compile with Cygwin, but I thought I had to poke in the code myself...ton wrote:Is this a question how cvs works?ztonzy wrote: btw, how do I myself now change the source to able to try this new feature?
Just make a checkout or update.
