Page 3 of 3
Posted: Thu Oct 09, 2003 12:00 am
by stiv
Thanks guys. That was extremely useful. Like the joke says, there is good news and bad news. The good news is this seems to be a completely standard python installation with nothing missing or strange. The bad news is there is nothing missing or strange in the paths or modules which would explain the problems we ( meaning you ) are seeing.
The message 'import site' failed; use -v for traceback" is coming out of Python, not blender code. Looking at the Python source and playing around a bit, I was able to create the message on my box by setting the PYTHONHOME env var to some bad value.
Dittohead, if I could impose on you one more time, let us try another test.
1) from a command prompt, as a regular non-root user, do the command.
env | grep -i python
When you did it before, that was as root. The root account is often set up differently than a regular user so let's be sure.
2) from a command prompt, as a regular user, go to the directory where blender is installed and run the command
PYTHONHOME=/usr ./blender
No, that is not a typo. Using PYTHONHOME overrides the normal search for python libraries. Python itself will append the /lib/python2.2 part. Putting it all on one line just sets the env var for that command.
I am running an older version of Suse, but I will try to build a static executable with some extra debugging code. I hate mysteries.
Thanks.
Posted: Thu Oct 09, 2003 9:59 am
by thornae
Don't know if this is related or not, but more information can't hurt. I've been having segfaults myself, and I've put up the gdb output
here.
Posted: Thu Oct 09, 2003 5:05 pm
by stiv
thornae wrote: I've put up the gdb output
here.
This looks to be something different. The Py_InitModule call in BGL_init is a place where we start passing around binary structs.
You are using Python 2.3. My guess is that there are some binary incompatibilites between blenders python 2.2 stuff and the new Python 2.3.
Posted: Fri Oct 10, 2003 7:32 am
by flb_z
For Mandrake9.1 I use this line to start it, and it work...
PYTHONHOME=/usr/lib/python2.2 ./blender
Loading required GL library /usr/X11R6/lib/libGL.so.1.2
But like you see site import failed again...
Like I said before In mandrake I use a lot of software that use Python and site-pack to! So, I dont tink it is a problem with python or bad env variable, the site-pack failed start whit release 2.28...
And segmentation fault start with 2.28c in adition of site import failed..
I wish these info will help...
Posted: Fri Oct 10, 2003 4:49 pm
by stiv
flb_z wrote:PYTHONHOME=/usr/lib/python2.2 ./blender
Try setting your PYTHONHOME like this:
Do NOT set it to the complete path.
If I set my PYTHONHOME to the full path to the python install, I get the import site failed message, too.
The full command for your machine is
Posted: Sun Oct 12, 2003 5:20 am
by dittohead
[nallworth@dittoBox nallworth]$ cd /home/nallworth/Blender/blender-2.28c-linux-glibc2.2.5-i386/
[nallworth@dittoBox blender-2.28c-linux-glibc2.2.5-i386]$ PYTHONHOME=/usr ./blender
Segmentation fault (core dumped)
[nallworth@dittoBox nallworth]$ env | grep -i python
PYTHONPATH=/usr/lib/python2.2:/usr/lib/python2.2/lib-tk:/usr/lib/python2.2/lib-dynload:/usr/lib/python2.2/site-packages:/usr/lib/python2.2/plat-linux-i386:/usr/lib/python2.2/site-packages/Numeric:/usr/lib/python2.2/site-packages/PIL:/usr/lib/python2.2/site-packages/gtk-1.2
Commands done in reverse order.
I have the Core if you want it!!
Posted: Sun Oct 12, 2003 9:01 pm
by flb_z
stiv wrote:flb_z wrote:PYTHONHOME=/usr/lib/python2.2 ./blender
Ok here is commands and result: My Linux mandrake 9.1 box
PYTHONHOME=/usr/ ./blender
#segemtation fault + site-pack failed
PYTHONHOME=/usr/lib/python2.2/ ./blender
# blender satrt and work fine; but site-pack failed
PYTHONHOME=/usr/lib/python2.2/site-pack/ ./blender
This is for blender 2.28c dynamic------------------
Now for Static 2.28c:
Bus error even no python message
noting show up ...
Tanks! Now I can run The version Cool (I sad that i can not use python but verry happy to have new radiosity) cool!
Posted: Mon Oct 13, 2003 12:39 am
by dittohead
Non of those work for me.
Posted: Mon Oct 13, 2003 2:28 am
by Jellybean
dittohead,
Try using this one I built from CVS (9/27). I wasn't able to get the download version working either.
blender-2.28c-linux-glibc2.3.1-i586.tar.bz2
Posted: Mon Oct 13, 2003 8:23 am
by flb_z
[quote="Jellybean"[/quote]
Yes your compiled version is working whit my system cool!
PS: Jellybean, are you getting site-pack failed message? On my side this message persist...
python + blender both working!
I do:
PYTHONHOME=/usr /ARK/BIN/blender-2.28c-linux-glibc2.3.1-i586/blender
Just litlle message left:
Xlib: extension "XFree86-DRI" missing on display ":0.0".
May be, it is because I put my 3d accelaration off (got system freeze whit ati rage 128 2000 if accelerated Xf86server is on) I use SVG Xf86server instead...
2.28c now working in Linux Mandrake 9.1
Posted: Tue Oct 14, 2003 5:08 am
by pastorJohn
First: Thank you Jellybean exceedingly for posting a working compile. You da man!
When I run it in console from the command line, I get the following output:
[office@family blender-2.28c-linux-glibc2.3.1-i586]$ ./blender
guessing './blender' == '/home/office/Blender/blender-2.28c-linux-glibc2.3.1-i586/./blender'
Could not find platform independent libraries <prefix>
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
When I run $ PYTHONHOME=/usr ./blender
I get:
guessing './blender' == '/home/office/Blender/blender-2.28c-linux-glibc2.3.1-i58 6/./blender'
Is this what I should be getting?
John Kiehn
pastorJohn
Re: 2.28c now working in Linux Mandrake 9.1
Posted: Tue Oct 14, 2003 5:07 pm
by stiv
pastorJohn wrote:When I run $ PYTHONHOME=/usr ./blender
I get:
Blender is actually running ok on a Mandrake box? Praise be to $DEITY_OF_YOUR_CHOICE.
The line about 'guessing' is just an info message from blender about where it thinks your executable lives.
The line about 'DRI missing' is a warning from X-Windows that the Direct Rendering Interface extension isn't available/supported.
