xgrid for mac os x - distributed rendering possiblities
Crasty
Post by Crasty »
For us mac os x users Apple who have access to more than one computer has released xgrid - www.apple.com/acg/xgrid/
It won't work with blender yet and i haven't read the development docs but I wonder what can be done for distrubuted rendering?
Money_YaY!
Post by Money_YaY! »
Oooo that would be really nice.
knoxer
Post by knoxer »
That would rock. The best part about Xgrid is that it uses Rendezvous (zero conf) to automatically find and connect to any other computers running Xgrid. It even knows how much processing power is available on each computer and splits up the job accordingly. It collects and assembles the pieces for you when the job is done too. It's idiot-proof clustering!
Money_YaY!
knoxer wrote:That would rock. The best part about Xgrid is that it uses Rendezvous (zero conf) to automatically find and connect to any other computers running Xgrid. It even knows how much processing power is available on each computer and splits up the job accordingly. It collects and assembles the pieces for you when the job is done too. It's idiot-proof clustering!
Perfect for me :D
somazero
Old thread, but...
Post by somazero »
Well, after looking for quite a while - I finally figured out how to use Blender with an Xgrid on MacOS X 10.4. If you're interested, please take a look at my howto at:
http://iwhir.net/?q=node/5
Let me know what you think...
Thanks!
czeky
Anyone lucky w Xgrid and Tiger?
Post by czeky »
that site is down …-(
render works perfectly in command line, but whe using xgrid.. i'm getting this
powerbook:~ user$ xgrid -h powerbook.local -job run /Applications/blender/blender.app/Contents/MacOS/blender -b ~/test2.blend -f 1
Compiled with Python version 2.3.5.
Checking for installed Python... got it!
$HOME is NOT set
$HOME is NOT set
Loading /Users/czeky/test2.blend failed: Unable to open
ERROR: No camera
many thanx for a help
jesterKing
Site Admin
Re: Anyone lucky w Xgrid and Tiger?
Post by jesterKing »
czeky wrote: Loading /Users/czeky/test2.blend failed: Unable to open
Make sure your test2.blend is actually in that location.
/Nathan
czeky
yes
Post by czeky »
yes, it is, rendering this command without xgrid part of the syntax renders just fine
just wondering, if its not because I don't have a shared volume mounted on all of the clients..
should I have blender installed on all machines in the same path? (I have) and should I have fg. NFS Shared volume for all the clients to access .blend file and to write a rendered frames?
many thanx
jesterKing
Site Admin
I'm not familiar with this particular solution, but from what I can gather, yes.
/Nathan
stiv
Post by stiv »
disclaimer: not an OSXer and never used xgrid
However, I would expect that all machines in the cluster need to be able to see /Users/czeky if they are going to open the file.
The "$HOME is NOT set" msg is the result of a missing environment variable that is normally set for processes. Blender is trying to evaluatle $HOME/.blender for finding python scripts.
