Emergency: Accidentally deleted workmesh: Help?
JoOngle
Post by JoOngle » Thu Feb 05, 2004 7:18 pm
I've just worked 7 hours in a stretch on an ear for my head-model
And i was about to clean up and press the "reference-plane-picture"
to delete it...but it deleted my entire mesh instead.
Any way to get it back? I have not closed the program yet.
Please don't tell me that I just lost 7 hours of work
because there are no delete-undo button?
*Edit*
I checked the temp directory, but it has somehow been oversaved
by the 5-minute autosave function - so blender magically
saved the blank file over the work. WAAAAAAAAAAAAAAHH
/JoOngle
theeth
Post by theeth » Thu Feb 05, 2004 7:33 pm
You didn't loose the mesh yet, you only deleted the object and unlinked the data.
You just need to create a new object (a Mesh) and relink to the correct data.
Any datablock that is unlinked will have a 0 before its name. This might help you find the correct one if you didn't name it properly.
Martin
- John Lennon
JoOngle
Post by JoOngle » Thu Feb 05, 2004 7:56 pm
No, it's gone. The TMP file that it saved over contains just
the reference picture of the ear that I drew after (a single plane)
the object however is lost...no links to it :(
Thanks anyway, Now I can learn to SLAVICALLY make backups
each and every hour instead of just nerding around the clock.
I made the PERFECT ear...and I even fell down the stairs today
(don't mind my ranting, I'm having ONE bad day)
Cheers and thanks for helping.
/JoOngle
SirDude
Post by SirDude » Thu Feb 05, 2004 8:20 pm
Just think the second one will be even better ;)
JoOngle
Post by JoOngle » Thu Feb 05, 2004 8:26 pm
True :) - It's just one of those days I guess. ;)
Cheers
/JoOngle
Apollux
Post by Apollux » Sat Feb 07, 2004 12:50 am
JoOngle wrote:No, it's gone. The TMP file that it saved ...
That was your fatal error.. in the moment that you try (and succed) to open another file, any un-linked mesh data from the file you were previously working on is lost forever.
The right thing to do (if it ever happens to you again) is: after you delete the valuable mesh, inmediately create a new one (a cube, i.e.), select the cube and do exactly as theeth told you... BUT DO NOT TRY TO OPEN ANOTHER FILE.
JoOngle
Post by JoOngle » Sat Feb 07, 2004 2:49 am
While this might be true Apollux, the "safe" way to deal with this
issue might be to save 3-5 "last-versions" of the currently edited-mesh
"example: blenderfile4283-ver-1.blend" etc. each five minutes.
3dstudio max does this (saves 3 versions behind...such as a history-save"
thus making sure that at least ONE of those files contains the lost
history.
take care,
Tommy
"Blender apostle - forever!"
z3r0_d
Post by z3r0_d » Sat Feb 07, 2004 4:17 pm
JoOngle wrote:While this might be true Apollux, the "safe" way to deal with this
history.
take care,
Tommy
blender does this too
(adjustable how many)
they are different by the extensions
blenderfile.blend <- newest
blenderfile.blend1 <- previous
blenderfile.blend2 <- before that (must increase number for versions to go this far, default goes back only 1)
ilac
Post by ilac » Sat Feb 07, 2004 5:37 pm
history.
take care,
Tommy
Though, afaik, in blender 'versions' only works for manual saves but not for autosaving. ie. autosaves saves to the same temp file. So you cannot have it save a different version every five-minutes automatically.
