What happened too....
engalicorn
Post by engalicorn »
I remember the transparent yellow face that you would get when you selected a face edit mode...
it looked soo good
what happend to it?
is there a setting to turn on and its off by default because it takes too much resources?
c.
IoN_PuLse
Post by IoN_PuLse »
Try the round theme in the theme switcher, I recall trying that theme out and those features came back, but I may be wrong....
If I'm wrong I'd like to know too :D
theeth
Post by theeth »
In edit mode, press the Draw Faces toggle button in the Editing window (F9).
In the last panel to the right.
Martin
- John Lennon
enriq766
You are a smart man!
Post by enriq766 »
Very cool. I thought the feature was gone too. Thanks
sedgetone
Post by sedgetone »
I'd like to see the faces change colour when you're in UV face select (mesh highlighted and you press f and select a face). It would make life a lot easier as it's sometimes quite hard to tell if you've deselected a face in a group of others. Or am I being thick and there's been a way to do that for years that I've not know about :?:
Sedgetone
guitargeek
Post by guitargeek »
I think someone is working on that. (faces being selected as they are chosen in the UV window)
