parallel computing + blender internal rendering=upcoming?
Goeland86
Post by Goeland86 »
Has anybody else ever had a cluster available and wished blender could include PVM ditribution for rendering? I personally have access to a 12 box linux cluster, one master node running debian, and the 11 others booting as diskless workstations through ltsp.
Can, or has anyone ever considered adding the little bit of code to the rendering engine to use the pvm librairies? Currently I have to export the blender animations with the povanim script to render them across the cluster with pvmpovray, an unofficial patch for povray3.5c.
It is a little annoying of having to export through povanim, as many settings are lost, and it sometimes creates directories that are over 1.99 GB (personal experience!!!) for animations.
A blender file on the other hand is 1.5MB, and blender can render from the command line.
Is there maybe another parallel computing library that can be used in blender? I know yafray supports openmosix... but I'm not too enthusiastic about openmosix (don't know how to set it up...).
Thanks for any help.
I am no programmer, therefore I don't know or understand the entire implications of implementing that...
Hope someone else thinks it's a feature worth having and starts looking into that as well...
JoOngle
Post by JoOngle »
Same here...
I've been offered to use ALL of our office and user-computers
at work (nighttime) with an FTP setup so I can render like crazy
if I want to (weeee!) But doh...How do I multi-render with Blender?
Network rendering? how?
I'd LOVE to be able to do this via FTP or TelNet...
It's like having access to a supercomputer..
/Tommy
S68
Post by S68 »
I have a linux cluster with PVM.
I've written a script top distribute rendering, actually it does not care of PVM, but uses rsh to launch separate chunks of an animation on separate machine.
Grab it at www.selleri.org/Blender
in the script section
Stefano
JoOngle
Post by JoOngle »
S68 - that would be really useful with an animation..
But - In my case it's a very "heavy" still image that I'm trying to get rendered with Yafray...unfortunately not even a 3 ghz P-4 with all
the memory in the world managed to get this scene trough the
first pass....
I rendered the above in one hour with the internal Renderer...
But yafray worked on it for 4 Days on 5 computers (different speeds
and settings)...and didnt even manage to get trough the first
render pass...:(
/Tommy
sten
Post by sten »
S68 wrote:I have a linux cluster with PVM.
Stefano
hey friend ;)
I noted that your link was wrong so I took the freedom to correct it for you... it said '.oerg' first...and I changed it to '.org'
cheers! ;)
Apollux
Post by Apollux »
I was about to recomend DrQueu, but the web-site seems to be down.
http://www.blender.org/modules.php?op=m ... =0&thold=0
kidb
Post by kidb »
render pass...:(
/Tommy
Could i have the xml file for testing purposes, or another time intensive yafray-testfile. I am working on a blenderrenderopenmosixknoppixcluster-cd.
kid.b@t-online.de for the xml and spam =8-)). Or can you post a link for downloading? Aehmm, please.
enigmasoldier
Openmosix for the not so openmosix inclined
Post by enigmasoldier »
The Clusterknoppix project is pretty sweet:
http://bofh.be/clusterknoppix/
Not only is the software great, but so is the webdesign (I did the webdesign)
It makes setting up a cluster easy for anyone and I have been using it before I got deployed.
kidb
Re: Openmosix for the not so openmosix inclined
Post by kidb »
enigmasoldier wrote:The Clusterknoppix project is pretty sweet:
Yep, i try to put it all together, removing stuff, which the real Blenderer does not need, and adding things like transcode, ffmpeg, so that you only put your .blend in a directory, and get later your ready-to-burn movie.
To test the posiblity of distributing yafrays render tasks, i should have a yafray-testfile, which takes hours on one pc.
JWalton
Post by JWalton »
i used mosix with blender before it was openmosix, and it worked very well.
