HLSL shaders
rstralberg
HLSL shaders
Post by rstralberg »
Are there any plans for implementation of HLSL shaders in Blender?
shadowman99
Post by shadowman99 »
Somebody correct me if I'm mistaken - HLSL is for Windows and Direct X, and Blender runs on many platforms that MS does not support with Direct X.
jesterKing
Site Admin
Post by jesterKing »
In tuhopuu gameengine you can find support for GLSL shaders.
(http://projects.blender.org/viewcvs/vie ... ot=tuhopuu)
/jesterKing
rstralberg
Shaders may be implemented i openGL also using
OpenGL® Shading Language
Here is a quote from http://www.theregister.co.uk/2003/07/01 ... ces_opengl
The HLSL was approved by the OpenGL Architecture Review Board, the standard's governing body, on 11 June and is likely to form the basis for OpenGL 2.0, the next major revision of the open graphics API.
More ...
http://www.opengl.org/documentation/oglsl.html
alien-xmp
Post by alien-xmp »
You can use GLSL in tuhopuu2.
Check out the PyDoc stuff for how to load your shader, and how to set uniforms, etc.
rstralberg
Many thank's JesterKing and alien-xmp, I will check that.
Panther
Post by Panther »
Excellent work Kester... this could be very promising indeed !!! :D
Quick question though...
Won't this kill / hinder the performance of the game engine to some degree ???
For example, the game engine isn't known for its speed ( no offence intended ), so wouldn't GLSL bring it down even more ???
On a side note...
Great news about the 'Shadow' support in the game engine, all of your work in this field is greatly appreciated !!! :)
Take care,
Panther
alien-xmp
Post by alien-xmp »
It really depends on the graphics card. I test with a Radeon 9800XT and a GeForce FXGo5200. The Radeon loves it, it barely misses a step. The FX5200 does get killed. :twisted: The FX5200 just doesn't have the fill rate, the speed is proportional to the size of the object being shaded.
Also, vertex buffer objects and display lists are in Tuhopuu2.
Also also, gcc generates faster code than MSVC (~33%)
Put these together, and I'm getting around 60fps with 100k onscreen quads. This is of course static geometry, deformed objects such as armatures and zsorted objects and the rest of the game will slow you down.
IoN_PuLse
Post by IoN_PuLse »
alien-xmp wrote: It really depends on the graphics card. I test with a Radeon 9800XT and a GeForce FXGo5200. The Radeon loves it, it barely misses a step. The FX5200 does get killed. :twisted: The FX5200 just doesn't have the fill rate, the speed is proportional to the size of the object being shaded.
There is a BIG difference between those two cards, especially in price. I hope you didn't mean it as a direct comparison of nvidia vs ati.
Which driver versions were you using for each as well?
alien-xmp wrote: Also also, gcc generates faster code than MSVC (~33%)
Do you have proof of this? I've read nothing but article after article stating the opposite.
Panther
Post by Panther »
ATI giving better OpenGL performance than NVIDIA... I never thought I'd see the day !!! :wink:
I'm using a standard ( not 'Go' ) 128MB GeForceFX 5200, what do you think my chances are of getting 60FPS performing a similar test to you - Good / bad ???
Interesting... is that documented somewhere / do all the developers know that ??? :?
I know we're speaking about Tuhopuu here, but does anyone know which compiler is used to generate all the 'Official' BF releases ???
SirDude
Post by SirDude »
I'm pretty sure everything execpt for Windows is compiled with gcc currently for the offical builds.
Panther
Post by Panther »
Thanks for the fast response SirDude !!! :)
alien-xmp
Post by alien-xmp »
Yeah I know. One of the nvidia papers showed a similar performance jump between the 5200 and their high end models. The FX cards also have a nicer shader engine (longer shaders, dFdx works.) The FX is also running at 1600x1200, while the ATI is at 1024x768, which is 240% more pixels to shade.
I mostly test driver 61.06 on Linux, and occaisionally use 61.76 on Windows. The ATI is on Catalyst 4.6. (Not the latest, but it will take me all day to download the next revision.)
I know, I was quite surprised when I saw it, and I only compiled with gcc because I was helping someone on IRC. I'm basing it on game framerates:
Ballercoaster: MSVC: ~120fps, gcc: ~160fps
55Wheels: MSVC: ~30fps, gcc: ~40fps
MSVC extra compiler flags: /Og /Oip /GR
GCC extra compiler flags: -O2 -ffast-math
theeth
Post by theeth »
Since the game engine is mostly C++, could it be that this speed increase is limited to C++ code for whatever reason? Because for the rest of blender, I've heard quite the opposite.
Martin
- John Lennon
IoN_PuLse
Post by IoN_PuLse »
So this is really a comparison of GCC for windows and MSVC?
