Page 5 of 7
Posted: Tue Dec 07, 2004 1:22 pm
by theeth
Yup, hash and xsort only work on vertice order, not faces order.
There's a sort function for faces, but I don't remember the hotkey.
Posted: Tue Dec 07, 2004 2:47 pm
by Caronte
theeth wrote:Yup, hash and xsort only work on vertice order, not faces order.
CTRL+F (Object mode)
Posted: Tue Dec 07, 2004 3:06 pm
by bertram
Caronte wrote:theeth wrote:Yup, hash and xsort only work on vertice order, not faces order.
Ahhh, thanks a lot.
So hashing/shuffling doesn't work for faces?
Is there a possibility to access the face index via python?
Posted: Wed Dec 08, 2004 11:18 pm
by Renderwoman
hey Intrr!
Pretty cool release!i've tested it.
Anyway, could you put LayerManager vertically and decrease the length? it's easier than the current way.
i've seen in another thread, a float with LayerManager on 3Dview, how d'you invoke it?
well, i go back to Blender!
cheers
Posted: Thu Dec 09, 2004 12:08 am
by intrr
Thanks Renderwoman.
The screenshot you've seen is from the old Layermanager, which got lost in a Disk crash. I did not convert the MKEY menu yet to reflect Layer names again. I will do that when I have time.
About the vertical Layout: I never use a vertical buttonswindow, sorry, so it's no priority for me.
Posted: Thu Dec 09, 2004 3:20 pm
by Renderwoman
No problem, finally we put up with it pretty quickly, anyway in the future it'd be cool to have choice, i don't say that for you, i think they will integrate it in the official branch.
Well, Thank you
EDIT1:Where is the pink ball aka the object pivot point? there's no toggle to enable it rather than annihilate it totally?
EDIT2: oh yeah, let's know if you take in account our comment lol, i know IBlender is a personal flavour of Blender.
Posted: Fri Dec 10, 2004 1:30 am
by intrr
Renderwoman: It can be enabled in the View properties header
(Enable the view3d menu, View->View Properties, Toggle "Centroids")
Posted: Fri Dec 10, 2004 1:35 am
by intrr
In the meanwhile, on popular request, a new feature:
Object Grouping.
http://blender.instinctive.de/downloads ... groups.txt
Example screenshot:
http://pub.instinctive.de/tables.png
This screenshot shows a table as a group of 5 objects. This group has then been ALT-D'd, which results in the second table. Then, both groups have been grouped again to form the "supergroup".
Thorough testing revealed no problems. As soon as I'm sure it's stable, a new release is ahead.
Posted: Fri Dec 10, 2004 3:05 am
by Money_YaY!
intrr wrote:In the meanwhile, on popular request, a new feature:
Object Grouping.
Example screenshot:
Aw I miss that old feature
Posted: Fri Dec 10, 2004 6:43 am
by intrr
Old? It has never existed, it's totally new... It's not the same as the old grouping in iblender1... This is completely animatable and stable
Posted: Fri Dec 10, 2004 11:54 pm
by Renderwoman
Intrr you are the man!!!
Group, Layer manager,ton's Outliner, well finally we have tools for better organisation!
Perfect about centroid toggle
i enjoy
EDIT: As you are the author of the layer manager, may i suggest to you one thing?
Well, can you change the drawmode for "protected" layer?
e.g: object from protected layer are in wireframe mode with a light colour (grey)
Or make a patch if you don't like this but you're nice
i should think you can write this quickly, if you want obviously.
thank in advance
Posted: Sat Dec 11, 2004 9:29 am
by intrr
Renderwoman: Thanks for the positive comments;
About the wireframe thing: Yes, that would be entirely possible, though I am not sure if it's that useful. For example, if you move the walls of your house on a locked layer, they will then appear as wireframe, and will effectively be invisible. You can rather turn off the layer completely then instead of locking it
Posted: Sat Dec 11, 2004 2:59 pm
by Renderwoman
Not necessarly, for exemple if you want to move object around rerference (e.g: background)
or just for those who want to keep an "unselectable" reference, a kind of template.
Anyway, you can choose the drawmode, or just change color for protected objects.
Just find a good way to see what is protected and what's not.
thank you
Posted: Mon Dec 13, 2004 5:22 pm
by macouno
intrr thanks man... I love the DOF (though am kinda miffed that I now "need" 4 sepparate blender builds to get all the functions I want).
Found a little "bug" and don't know yet whether it's instincive only... puters busy rendering now, can't test till it's done.
When I now render an anim and set it to save as a series of bitmaps (BMP) with auto extentions it doesn't save with the extentions, only the filename. It works fine with PNG which is fine by me as well. Just thought I'd let you know.
Posted: Mon Dec 13, 2004 5:42 pm
by intrr
macouno: Thanks for using and testing. Well, I consider BMP an utterly useless file format and never use it myself, so I can't comment on it - but it's probably a non-instinctive-related bug then, because I didn't touch the BMP code.
