Current projects + todo + release schedule
ton
Site Admin
Post by ton » Tue May 03, 2005 3:56 pm
Hi all,
Below the overview of "current projects", with todo items.
Proposed is doing a cvs-freeze (Bcon-4) in 1 or 2 weeks, release itself 10 days after.
For everyone; the "new" points below are the areas we can use testing for. And cool sample files where appropriate!
(Also posted on main developers mailing list, thought would be nice to copy it here for all)
---------> Render
New:
- Transparency filter
- Threading
- FBuf
- Ortho render
- Bump map fixes
Todo:
- Try to get ray-traced image filter fixed (Ton)
- OpenEXR still feasible? Kent?
--------> New Transform
New:
- complete system was redesigned & developed
- more elaborate constraint access with MMB
- same for hotkeys X, Y, Z
- planar constraints (SHIFT+)
- proportional mode: "only connected"
- more proportional types (sphere, linear, ...)
Todo:
- Mirror menu still uses old transform code (Martin?)
- Externally setting local constraints for pulldowns (Martin)
- Negative scale bug (Martin)
- restore old style constraint line drawing (done)
- theme colors to adjust XYZ colors (Ton will check)
- Icon and button for new PET (done)
--------> 3D Manipulator Widgets
New:
- could be added thanks to transform recode
- Option in header (hand icon) enables widgets for translate/rotate/scale
- offers global/local and normal alignment
- hold SHIFT for planar constraint
- hotkeys CTRL+SPACE, ALT+SPACE
Todo:
- hotkey access is still not as nice as it could be. Probably would need cleanup of entire global hotkey list
- Icons in header are a bit ugly. Replaced with simpler shapes for now.
--------> Softbody
New:
- each object type (now Mesh, Lattice implemented) can become softbody
- works with particle force fields & deflectors
Todo:
- Baking (done)
- docs & demos!
--------> Dependency Graph
New:
- code added to solve dependency issues in our animation/relation system
- now used for pre-sorting base-list (Scene object list) to define order of calculations
Todo:
- make higher level API for Blender to talk to dep graph
- include in Transform
- use it to calculate object matrices and deforms
(todos might be no release target...)
--------> New Subsurf
New:
- faster subdivision susrface code, including incremental updates
- improved crease support
- full recode of Mesh drawing methods
Future ideas:
- integrated modifier stacks
- adaptive display for render
- LOD
- lower resolution in octree for speedup
--------> GUI stuff
New:
- a lot of work going on in Tuhupuu3 still
Todo:
- Most Tuhopuu work, including lamp drawstyles, moved to other release?
- Timeline is appreciated a lot, could be moved over, in own spacetype. (Ton)
--------> Mesh tools
Todo:
- Subdivide recode? (Johnny)
- Loop operations recode? (Tom)
- patch for immediate extrude? (Ton reviews)
--------> Post-production effect: ZBlur
New:
- it's the zblur sequence plugin, tied to render output itself
- functionality highly limited... antialias & blur errors by implementation
Todos:
- put zmin & focus clue in camera draw limits?
- docs, sample filess + tutos to show usage and limitations
- Add a straight 'blur' itself as posteffect, so you can overlay scenes
- Ipos on all of this...
(Latter 2 todos might not make it)
--------> Python
New:
- Text3d module (Joilnen, still working on it)
- On-load script setting (Willian)
- New scripts bundled in, VRML/XML? (Willian)
Todo:
- Space-scripts concept (Willian), might be next release
--------> Texteditor
Todo:
- bracket matching needs theme color decision
- syntax color patch
(Rick (antihc3) will make patch, Ton checks)
--------> New .B.blend
Todo:
- default lamp has weird clip start/end for spot shadow
- general re-check of standard color conventions (Matt?)
- add as extra the orange theme?
- manipulators on?
-Ton-
OTO
Post by OTO » Tue May 03, 2005 5:25 pm
Hello
all this is great!! Thank you! But ( yes, there's always one but) not even
one little line about the Game engine?! :
Is coding for the game engine very hard or not interesting....?
SamAdam
Post by SamAdam » Tue May 03, 2005 10:55 pm
very nice work.
this is quite reassuring. I see everything i noticed in there.
Now I can stop complaining.
thank you.!
mjordan
Post by mjordan » Wed May 04, 2005 2:50 pm
What about FTGL integration into the build process?
Actually FTGL (bFTGL) in blender/extern/bFTGL has to be manually configured/installed before international support can be compiled in. And this is not even documented. The main README file is out of dated too.
Regards,
Renato Perini
You can't live with women, you can't live without women.
Fuzzy logic example.
SirDude
Post by SirDude » Wed May 04, 2005 2:58 pm
Hi mjordan,
I'm assuming your talking about scons and bFTGL?
Try patching your blender with the following patch:
http://projects.blender.org/tracker/ind ... 9&atid=127
I don't actually have blender building with scons on my systems so
if you could test it out and send me an email with results we can get
this tested and working.
Thanks.
(my email is mein@cs.umn.edu)
mjordan
Post by mjordan » Wed May 04, 2005 4:22 pm
SirDude wrote:Hi mjordan,
Thanks.
Yes. This is *exactly* what I was asking for. I'm going to give your patch a try. I'll email you as soon as I get things working/tested.
Regards,
Renato Perini
mjordan
Post by mjordan » Wed May 04, 2005 4:51 pm
Thanks.
You have mail
Regards,
Renato Perini
dsp_418
Post by dsp_418 » Wed May 04, 2005 5:37 pm
Any chance to animate the parameters of the scripts in a next release?
gabio
Post by gabio » Wed May 04, 2005 6:05 pm
dsp_418 wrote:Any chance to animate the parameters of the scripts in a next release?
if you'r talking about python script, you can already do so. it's just no very simple to find.
Now that we have acces to ipo curve, you can put your value on one of the ipo channel of an empty, and read the value of the ipo on each frame. Most probably you would want to animate these value when your script is linked to scene on a framechange event...
dsp_418
Post by dsp_418 » Wed May 04, 2005 6:32 pm
thanks for the reply gabio,
just wanted this:
"It would be cool to animate parametric values in a script. For example, take the L-System: you could make it growing simply modifying values. Or ANT script, to make the landscape animating. The same for Discombulator, extruding faces from 0 to ... N. "
Pierre-Luc_Auclair
Post by Pierre-Luc_Auclair » Wed May 04, 2005 9:08 pm
Sorry to be an ass and hijack the discussion, but maybe for once it'll be heard.
Could you please add the Two Sided surface drawing mode of UV Face Select Mode to Edit Mode, and properly rename the Double Sided surface type to Backface Lighthing.
I'm sure it's not hard to do, please add this.
kxs
Post by kxs » Wed May 04, 2005 9:25 pm
Is there any chance of adding the "change shadow color" option in the 2.37 release? I`m not a coder so not so sure, but maybe it is not so hard to do that.
kxs
Post by kxs » Wed May 04, 2005 10:07 pm
Does it normal that Hemi casts shadow? Try this in the default scene with cube:
-add plane under the cube
-add new material to the plane
-in the material, in Mirror Transp turn on Only Shadow
-select lamp
-turn on Ray Shadow (important!)
-then change the lamp type to Hemi
-render
tada! Hemi with shadow.
Is this a bug? I thought Hemi doesn`t have one. You can turn off the shadow by selecting spot or Sun, turning off shadow and selecting Hemi again.
Tried this on 2.36 and the latest 2.37 testing build on linux.
kxs
Post by kxs » Fri May 06, 2005 10:51 pm
whoa! One thing you must repair:
when you selct few vertices in Edit Mode, hit TAB and again TAB to go back to Edit Mode, some vertices are unselected. Try it with more complicated objects, `cause cube, for example, works fine
lukep
Post by lukep » Fri May 06, 2005 11:18 pm
kxs wrote:Does it normal that Hemi casts shadow? Try this in the default scene with cube:
Ray shadows are available with *all* lamps
