GCC 4.0.0 Internal Compiler Error
mjordan
Post by mjordan »
Hi all.
Just compiling actual CVS tree with some optimizations (scons + Linux + gcc 4.0.0):
There are the used parameters:
Code: Select all
release_flags = ['-march=athlon-xp', '-O3', '-pipe', '-fomit-frame-pointer', '-ffast-math', '-mfpmath=sse,387', '-msse', '-mmmx', '-m3dnow', '-Wno-unused-parameter']
Code: Select all
extra_flags = ['-pipe', '-funsigned-char']
cxxflags = ['-O3', '-fvisibility=hidden', '-Wno-unused-parameter']
The build process goes smooth, until it reached the editipo.c file in $(MAINTREE)/source/blender/src and I receive the following GCC crash:
gcc -pipe -funsigned-char -march=athlon-xp -O3 -pipe -fomit-frame-pointer -ffast-math -mfpmath=sse,387 -msse -mmmx -m3dnow -Wno-unused-parameter -Wall -W -D_REENTRANT -DGAMEBLENDER=1 -DUSE_SUMO_SOLID -DNDEBUG -DINTERNATIONAL -DFTGL_STATIC_LIBRARY -DNAN_BUILDINFO -Iintern/guardedalloc -I/home/mjordan/Blender/build/linux2/source/blender/blenlib -Isource/blender/blenlib -Isource/blender/blenlib -I/home/mjordan/Blender/build/linux2/source/blender/makesdna -Isource/blender/makesdna -Isource/blender/makesdna -I/home/mjordan/Blender/build/linux2/source/blender/blenkernel -Isource/blender/blenkernel -Isource/blender/blenkernel -I/home/mjordan/Blender/build/linux2/source/blender/include -Isource/blender/include -Isource/blender/include -Iintern/bmfont -I/home/mjordan/Blender/build/linux2/source/blender/imbuf -Isource/blender/imbuf -Isource/blender/imbuf -I/home/mjordan/Blender/build/linux2/source/blender/render/extern/include -Isource/blender/render/extern/include -Isource/blender/render/extern/include -Iintern/bsp/extern -I/home/mjordan/Blender/build/linux2/source/blender/renderconverter -Isource/blender/renderconverter -Isource/blender/renderconverter -I/home/mjordan/Blender/build/linux2/source/blender/radiosity/extern/include -Isource/blender/radiosity/extern/include -Isource/blender/radiosity/extern/include -Iintern/decimation/extern -I/home/mjordan/Blender/build/linux2/source/blender/blenloader -Isource/blender/blenloader -Isource/blender/blenloader -I/home/mjordan/Blender/build/linux2/source/blender/python -Isource/blender/python -Isource/blender/python -I/home/mjordan/Blender/build/linux2/source/kernel/gen_system -Isource/kernel/gen_system -Isource/kernel/gen_system -Iintern/SoundSystem -I/home/mjordan/Blender/build/linux2/source/blender/readstreamglue -Isource/blender/readstreamglue -Isource/blender/readstreamglue -I/home/mjordan/Blender/build/linux2/source/blender/img -Isource/blender/img -Isource/blender/img -I/home/mjordan/Blender/build/linux2/source/blender/quicktime -Isource/blender/quicktime -Isource/blender/quicktime -Iintern/ghost -Iintern/opennl/extern -I/usr/include/python2.3 -I/usr/include/SDL -I/usr/include -I/usr/X11R6/include -I/home/mjordan/Blender/build/linux2/source/blender/ftfont -Isource/blender/ftfont -Isource/blender/ftfont -c -o /home/mjordan/Blender/build/linux2/source/blender/src/editipo.o source/blender/src/editipo.c
source/blender/src/editipo.c: In function 'movekey_ipo':
source/blender/src/editipo.c:4395: internal compiler error: in fold_convert, at fold-const.c:1922
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://gcc.gnu.org/bugs.html> for instructions.
scons: *** [/home/mjordan/Blender/build/linux2/source/blender/src/editipo.o] Error 1
scons: building terminated because of errors.
Don't know how to do a full bug report. If someone can help me it will be much appreciated.
Thank you.
Regards,
Renato Perini
You can't live with women, you can't live without women.
Fuzzy logic example.
stiv
Post by stiv »
This is a gcc problem. You should talk to them about it.
You might also try losing the -O3 flag and using -O2 instead. May it will work with less optimization.
Michel
Location: Somewhere below the rivers in Holland (but not Limburg)
Post by Michel »
The problem is in GCC, not in Blender. If you want to submit a bug there, you should ask this question on their site. The url for instructions in located in the error message you posted.
With regards,
Michel
You can have one of two things: Progress or Progress Reports.
mjordan
Post by mjordan »
I know it's a GCC bug. My problem was HOW to generate a correct preprocessed source file.
But I solved the problem myself.
This is the full bug report to GCC developers:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=21379
Regards,
Renato Perini
