SimbiontBlender 0.4
Posted: Fri Jun 24, 2005 3:30 am
by pbridger
Cross-posted from Elysiun:
Yesterday I rewrote SimbiontBlender. The new version has a number of changes:
- colour tweak preview
- much more flexible mapping of DarkTree output to Blender texture
- ability to remove active DarkTrees
- the script now communicates directly with the plugin dll, removing the need to 'Update' your texture before rendering
- opened DarkTrees are saved in a config file in the .blend
The updated tutorial is in the usual place:
http://ten-ninjas.com/SimbiontBlender/
If you have trouble understanding the new channel mapping the tutorial is the first place to look.
The 0.4 version installer is here:
http://ten-ninjas.com/SimbiontBlender/S ... latest.exe
(You nolonger need to download any dlls separately, this should install everything you need).
Let me know if you have any issues.
Enjoy!
Posted: Fri Jun 24, 2005 2:07 pm
by kirpre
This plugin looks amazing and I have read over the tutorial. The problem I am having is understanding how to connect the DarkTree shader to the object I want it to be displayed on. This section is not very clear to someone (like me) who is not a textures wiz. Perhaps you could include a sample Blend, I always learn best from examples.
Thanks for your work.
Posted: Fri Jun 24, 2005 3:15 pm
by pbridger
Yeah I apreciate the plugin can be a bit confusing.
I want to include a sample .blend, but this is problematic because blender would not be able to load the DarkTrees automatically (if the user has a different install directory than the default).
I'll try to help:
1. Give your object a material. F5KEY, 'Add New'
2. Add a texture. F6KEY, 'Add New'
3. Change the texture type to 'Plugin'
4. Load the SimbiontBlender plugin with the 'Load Plugin' button.
To do this you will need to navigate to your <blender install>/.blender/plugins/SimbiontBlender directory. Open SimbiontBlenderDll.dll in this directory.
5. Open the SimbiontBlender python script. Scripts->Materials->SimbiontBlender
6. Load a DarkTree texture with 'Add Texture'. There are some samples in the plugin directory.
7. Activate the DarkTree colour channel (select Colour in 2nd menu in the Channel Outputs section).
8. Set up camera and render.
Good luck!
Posted: Fri Jun 24, 2005 4:18 pm
by kirpre
Thanks, works great now. Look forward to some play time.
Posted: Sun Jun 26, 2005 12:08 am
by cekuhnen
i still dont understand this one!
you dont need to use their software to
be able to use the the shaders?
can you craete procedual shaders or can you
only use premade shaders in blender with
this simbiont?
claas
Posted: Sun Jun 26, 2005 12:40 am
by Bellorum
cekuhnen wrote:i still dont understand this one!
this simbiont?
claas
You can use premade procedural shaders made with the Darktree software, but you'll need the Darktree editor to edit the shaders, or make new ones.
Posted: Sun Jun 26, 2005 4:11 am
by cekuhnen
hi
blender gives me this error:
file "string", line 37
import error: no module named re
can you tell me what goes wrong?
claas
Posted: Tue Jun 28, 2005 11:22 pm
by cekuhnen
wrong python installation. 2.4 did not work
Posted: Wed Jun 29, 2005 7:19 pm
by jgaray
Can't get it to work.
I get a window that says it can't find msvcr71.dll
Posted: Wed Jun 29, 2005 8:18 pm
by mchs3d
jgaray wrote:Can't get it to work.
That's odd. :? The DLL it needs is the Microsoft Visual C++ Runtime dll. Somehow the way he built it made it require that that dll was with it.
Posted: Thu Jun 30, 2005 11:10 pm
by jgaray
Downloaded msvcr71.dll from the web and saved it to the plugins/SimbiontBlender directory. It works now!
