Sound in blender
yertari
Sound in blender
Post by yertari » Sat Oct 01, 2005 8:37 am
How does sound work in blender?
I have just made a sci fi based music pack that i am selling for the various game engines in mp3 and ogg format, and am wishing to know if sound works well in Blender? and is easy to use. Does blender use ogg?
http://www.arteria-gaming.com
simonharvey
Re: Sound in blender
Post by simonharvey » Mon Oct 03, 2005 4:13 am
yertari wrote:Hi,
To the best of my knowledge blender only supports 16 bit wav audio streams.
Simon
juanjavier_xxx
Post by juanjavier_xxx » Fri Oct 21, 2005 7:55 am
Simon
---How can you manage to make sound work in blender? I am using it under Debian GNU Linux (kernels 2.6.8 and 2.6.12) and I am completely unable to make sound work.
Whenever I try to play a sequence with imported wav at 16 bits, console says
Code: Select all
Unable to open audio: No available audio device
Audio works correctly on every application outside Blender, such as VLC, Mplayer, Audacity audio sequencer, and so on.......I tried with the onboard sound and with the PCI 128 Ensoniq chipset from Creative SoundBlaster. I tried turning onboard chip off in the BIOS as well...nothing works: audio gets imported but does not sound.
What is wrong?
Thanks.
simonharvey
Post by simonharvey » Fri Oct 21, 2005 11:45 pm
Blender's sound system in linux has always been a bit flakey, if you have compiled it from source you will have to enable in in the toplevel SConstruct file, other than that I dont know what to say to help you.
Kind Regards
Simon Harvey
juanjavier_xxx
To whom may interest about sound in blender:
Post by juanjavier_xxx » Sat Oct 22, 2005 11:02 am
simonharvey wrote:Blender's sound system in linux has always been a bit flakey,
Simon Harvey
Yeah, you can bet it for sure ;-P LOL
But anyway got issue solved:
Blender starts the sound system of the game engine by default. So actually it gets control over one sound device of the computer just at blender boot.
If you try to import audio on the sequencer and then play it, Blender will complain that the audio device is busy, and thus not available. No sound will come out. And that was my issue.
You have to tell Blender at startup that don't get any sound device occupied by starting it from the console and typing
Code: Select all
blender -g noaudio
if you want it full-screen or
Code: Select all
blender -w -g noaudio
if you want it window-resizeable.
That worked for me. Hope it heps.
