Sound in Blender 3D
Posted: Wed Oct 26, 2005 8:26 pm
by tioilmo
Hi folks !
Do you intend to extend the other sound file extensions in the new version 2.40.
For example : MP3 and MID
I think with these two additional types of sound files Blender 3D will cover the most important kind of sounds available in the Internet to use in our projects.
I hope you should think about this issue. The WAVE sounds (available in the current version) are very big comparing to these two types of sounds.
That´s my recomendation.
Thanks,
Ilmo
Posted: Thu Oct 27, 2005 7:51 am
by z3r0_d
yes, but how?
Posted: Tue Nov 01, 2005 3:51 pm
by Sugardude
mp3 is a compressed wav-type file, so technically, anything that can play wav can play mp3 with the correct codecs, I don't understand why mp3 isn't implemented in Blender yet...
However, midi (.mid files) aren't actually sounds, they are commands that tell the computer to play a set of already existing sounds. When you play "midnight sonata.mid" (just an example, it's a sonata for piano only), the computer reads the commands in the midi file, ie : instrument, note, velocity (how hard it was pressed), and it does this for each note in the file.
Implementing this into Blender would be odd, there would have to be sounds to associate midi files to within Blender (or Blender could go and get the midi sounds supplied with your computer (usually with the sound card).
A better idea would be to use a music editing program, enter the *.mid file, and associate channels to samples by hand before exporting as a *.wav (or mp3 if it get's supported by Blender).
Posted: Tue Nov 01, 2005 5:51 pm
by OTO
Hello
I've read somewhere ( Ton's post) that Blender will integrate the Ffmpeg
library, so many, many formats will be available
Unfortunately not OGG I guess :(
Please don't use MP3 format. It's license protected
Bye
Posted: Wed Nov 16, 2005 7:43 am
by ysvry
i once made mp3 with .wav extension and they worked fine.
Posted: Wed Nov 16, 2005 9:36 am
by joeri
I hope blender will one day become a professional video editor.
That will blow finalcutpro from the earth. Or something more modest will be fine to.
But for blender to become an audio edit program?
Importing midi files does not strike as needed to me as suggested in this post.
Reading mp3's might be a bit more, although I don't know why you would want to edit with a lossy file format.
The diskspace argument is weird, specialy because a 5 minutes wav takes less disk space then half a second of animation.
Posted: Wed Nov 30, 2005 3:57 am
by Ammusionist
Doesn't Python describe a MIDI API?
I guess some bright spark could add a python MIDI script.
Personally, if I want to use a MIDI in Blender, I use Audacity to record the MIDI playing throught the computer's synthesyzer and save it back as a WAV.
Posted: Wed Nov 30, 2005 7:33 pm
by lightning
joeri wrote:The diskspace argument is weird, specialy because a 5 minutes wav takes less disk space then half a second of animation.
...assuming that the animation is uncompressed? Blender supports loads of codecs for animation, but only wav for audio.
Posted: Thu Dec 01, 2005 4:42 pm
by bmud
There are a lot of sound formats that are not supported yet. If you're running the game engine, mp3 and MIDI are not the only desireable formats, so one must use an outside python-bound library.
fmod
openAL
openAL is currently being implimented into Blender (sloooowly). I'm all for implementing multiple libraries such as openAL to handle mp3/ogg/wav and then something else for the game engine so it can handle it/xm/s3m/mod/wav/mp3/midi/ogg
For any of you out there that don't play with sound very much, believe it or not, good sound mixing is only as good as the software allows. Right now the best wave editor out there is probably Adobe Audition 1.5.
I've tried doing a lot of research on sound support in the past mainly for the blender community game project. Feel free to search my name on http://bcgp.dyndns.org for some more threads that might prove useful, and a lot of dead ends too.
