Blender for windows Compiled and running ! Details....
gorgan_almighty
Post by gorgan_almighty »
ok nikolatesla20 ive tried yr binary. all vry good, most of it works fine, yr rite no physics. bt as for python scripts, some of my old ones seems 2 work and som don't :?
anyway r u goin 2 try and get physics workin? id look forward 2 that, and the publisher key thingy as well.
Keep up d good work :D
Saluk
Post by Saluk »
Great work niko, I knew you could do it!
I wouldn't expect physics to work without the solid collision library, but at least everything else seems to work. I put up a test render:
Came out as expected.
I also loaded a few of my games and they seemed to work just fine, no physics of course.
Saluk
Post by Saluk »
Gorgan_almi: the collision library was NOT GPL, so ton had to get rid of it. This I expect is what is causing the physics woes, and will not be an easy fix.
Although if anyone could do it, Niko could:)
fogof
Post by fogof »
Saluk wrote:Gorgan_almi: the collision library was NOT GPL, so ton had to get rid of it. This I expect is what is causing the physics woes, and will not be an easy fix.
Is the API for the physics lib available? Maybe we can recode it.
dittohead
Post by dittohead »
YOU ROCK!!!!
8) 8) 8)
dittohead
RiNiK
Post by RiNiK »
little note... so great the blender works, but there is still some problems... example that the subsurface wont work... it's seems to be fine when you look at it in the modeller but try to render it...
Goofster
Post by Goofster »
RiNiK wrote:little note... so great the blender works, but there is still some problems... example that the subsurface wont work... it's seems to be fine when you look at it in the modeller but try to render it...
Be aware that you have to set BOTH subsurf buttons. it works fine for me
RiNiK
Post by RiNiK »
thanks. now it's workin' :)
nikolatesla20
Subsurf
Post by nikolatesla20 »
Yes, I just noticed that, it must have been a new feature.
There is a second button , a little one, that determines the subsurf amount for the rendering. The big button is the amount for the interactive display.
-nt20
Goofster
Post by Goofster »
I promise you you'll grow to love that new feature :)
Manuel
Post by Manuel »
On my win2000 ithe boolean don't work...
I make two sphere, select both and push W-Key.
I don't see any message...Blender is mute...where is amy error??
:cry:
Please, help me...
nikolatesla20
booleans
I changed LICENSE_KEY_VALID to TRUE and recompiled
Boolean ops work now for me....
Wow about time we had these. Very nice. Now to see if I can turn on NLA.
-nt20
Saluk
Post by Saluk »
I think NLA was in the works, so it may not all be there or complete, but good luck seeing what you can do.
Great work so far.
nikolatesla20
reuploaded
I reuploaded the binary with my recent changes.
-nt20
nikolatesla20
NLA
Saluk:
All the NLA code appears to be done and functional, I just have to enable it yet. Still looking.
-nt20
