Rendering layers.
Skelet
Rendering layers.
Post by Skelet »
Is there a posibility to render just a selected layers, not all?
The Skelet
Mats78
Post by Mats78 »
Blender renders only the layer(s) you have selected. So if you have layer 1 selected but all your lamps are in layer 2 you won't see anything - you gotta select both layers. I usually use the layer feature alot =) I think it works very well - it's easy to use and allows for different setups for rendering. Much esier to model if things are spread out a bit as well.
Skelet
Post by Skelet »
Hey!
I'w try it on a new project, it works, but when I'm rendering my old project, it rendering all layer's, not just selected. Maybe there is too much meshes? Here you can see it here => http://www.absolute.lv/alfa155.jpg
The Skelet
Mats78
Post by Mats78 »
Hmm.. then I'm not sure what's wrong, maybe you could post your .blend file here so I could take a look at it?
NateTG
Post by NateTG »
it is possible for a single object to be active in more than one layer. you may have accidentally done this. make sure your objects are only in the layer(s) you want. (select objects(s) and press M key.)
Skelet
Post by Skelet »
Try'ed, false... Mats78, give me you'r mail, I ll send you the file
The Skelet
SirDude
Post by SirDude »
If he doesn't respond you can send it to me and I'll take a look at it.
mein@cs.umn.edu
Mats78
Post by Mats78 »
metoo =) here's my mail :
mats.holmberg@welho.com
