free gelato
marioamb
Post by marioamb »
New version 0.11:
http://www.kino3d.com/forum/download.php?id=3674
- new GUI
- create a small ASCII file
- parameters dither and quantize
- add new file format SGI, BMP, PCX and DDS
- select the compression algorithm for TIFF and OpenEXR
- add new data types "RGB + Z" and "RGBA + Z", creation of separate files for colors, and Z channel
- support for DoF (Depth of Field)
- animation support
- partial support for texture and UV mapping
- file name for MS-Windows (no testing)
- use psyco if available
Example of DOF:
Simple animations:
http://media.putfile.com/Gelato-Test
http://media.putfile.com/Gelato-DoF
marioamb
Post by marioamb »
New version 0.12:
http://www.kino3d.com/forum/download.php?id=3751
- new file format PNG, IFF (Maya) and RAW
- it is possible to assign materials to Gelato shaders
- set the name and scaling of the units
- debugging shaders: shownormals, showfacing, showst, showuv, showdudv, showgrids, raygoggles
- preview value
- multi pass render beauty and/or shadow and/or ambient occlusion
- support for border render
Simple example:
Ambient occlusion
Beauty
Beauty + ambient occlusion
tenebrusmke79
One of the drawbacks of this is you have...
Post by tenebrusmke79 »
to have NVIDIA.. and I don't have NVIDIA, I have Intel as my graphics driver. I would have wanted to try this otherwise.
Sad, though. It looks like it's an awesome tool.
marioamb
Post by marioamb »
New version 0.14:
http://www.kino3d.com/forum/download.php?id=3924
  • - Bug fix
    - Blender 2.43 and Python 2.4 or above is required
    - Sets the size x and y of the screen buckets
    - Enable and set the file to write the error log
    - Split out objects into separate files
    - Image file output section name.NNN.ext or name.ext.NNN, where NNN is frame number
    - Support for SubSurface Scattering. First step enable bake diffuse from mesh's property and enable SSS pass. Second beauty pass to use shader that also incorporates SSS, for example plasticss.
Test SSS:
3D Object "Happy Buddha" from
http://www-graphics.stanford.edu/data/3Dscanrep/
Simple animation:
http://media.putfile.com/Gelato-Sub-Sur ... ering-test
