Radiosity modelling suggestion
credo
Post by credo »
Hello there,
I'm very impressed with Blender's radiosity capability, and I use it often as a modelling tool. However, I find it offputting that it generates a model with so many subdivided faces that I have to discard the model if I want to change it in some way.
Instead of subdividing faces, would it be possible to store the new information as meta-data associated with each face? Eg, each face has a list of intersection points etc. This information would expire as soon as a particular face was modified, and radiosity calculation would need to be recalculated. That way, my beautifully designed model wouldn't be cut up into many unmanageable pieces each time I used the radiosity function.
Please let me know if I'm just being dumb and barking up the wrong tree lol.
Cheers
ysvry
Post by ysvry »
no man, this is a great ideer, i might have thought of it myself, i say implement it.
credo
Post by credo »
Is there any formal process of requesing a feature? I might be able to code it myself, but I'm unfamiliar with Blender's code base, and I haven't had experience with such a large project before.
epat
Post by epat »
I think the radiosity code in blender needs a recode anyway so it probably isn't that easy to add - but you might be able to persurwade someone to do it with a bounty if you want it that desparately!(or you could try on http://www.blenderjobs.com) -epat
'Regret for wasted time is more wasted time.'
- Mason Cooley
Toon_Scheur
Post by Toon_Scheur »
I haven't used radiosity in a long time, so maybe I'm missing something. So you want to edit your mesh after the radiosity calculation? I thought that the only side effect was that everything becomes one mesh so you have to seperate them. But as far as meshes ending up subdivided.... I think I have to try that out again... but there is a replace and add mesh option.
I'll try this ( http://mediawiki.blender.org/index.php/ ... cy_Example ) again to see what you exactly mean.
credo
Post by credo »
Well, if you choose "Replace Mesh", you lose your original model, which is replaced by a heavily subdivided model that is difficult to work with. If you choose "Add Mesh", you have the difficult task of moving your original mesh out of the way and then rendering with the new mesh. Then, you must delete the new mesh and replace it with the old one if you wish to keep working. This can be a bit of a pain if you are doing frequent radiosity calculations.
