OS X Fonts
Cyberpawz
OS X Fonts
Post by Cyberpawz »
Where do the fonts for Blender go in for OS X? I only have one font, and I need about 30 or so to get what I need done..
Any Help would be appreciated.
Jens
Post by Jens »
Hi Blender-Men
Iám interested in an answer too?
I suppose they must be TTF ? like OpenOffice needs them ?
Greetings...Jens
SirDude
Post by SirDude »
blender only has one default font. It doesn't require you to store fonts
anywhere. You can just click the load button and then browse for a
ttf or a type1 font. Basically blender will have a little square box next to the fonts it recongnizes. Just look for it and go...
Its probably a good idea once you find a font you like for a project to copy
that font to the directory where your blend file is. That way if you need to move things you'll have it.
Cyberpawz
Post by Cyberpawz »
SirDude wrote:blender only has one default font. It doesn't require you to store fonts
Was afraid you were going to say that...
Jens
Post by Jens »
Hi
Thats not a problem. One can get TTF-Fonts easily.
Should be a good idea to have a ttf-folder in the blender-folder.
Iám not shure about type1-fonts, but there are ways to transform
Mac-fonts to TTF, which i will do then.
One of these "transformer-progs" whre included in former OpenOffice
versions, i remember.
Greetz...Jens
matt_e
Post by matt_e »
Blender can also use Type1 PostScript or OpenType fonts, both of which are quite common on the Mac.
On the Mac, your fonts are probably at /Library/Fonts or /System/Library/Fonts.
Jens
Post by Jens »
You´re right.
But in the filedialog i can´t see immediatly what kind of font it is,
only when it has a discrete wildcard a la .ttf or so.
In case of non-matching format, you will get an errormessage.
So to avoid confusion, i prefer to have the fonts handy as ttf in
a special folder, thats all.
Thanks for youur help....greetz...Jens
