Basic Noob Question
gray_
Basic Noob Question
Post by gray_ » Fri Feb 16, 2007 2:40 pm
With the default install of Blender, I create a new scene. Up pops the cube.
I select the cube, duplicate it and rotate the duplicate 45 degrees about the Y axis (forming a kind of star shape). Then I hit F12 to render.
Why do I see a load of corruption on the top of the rendered shape?
- Gray
Caronte
Post by Caronte » Fri Feb 16, 2007 2:54 pm
You need to scale one cube a bit ;)
Caronte.
http://www.nicodigital.com
qwequ777
Post by qwequ777 » Fri Feb 16, 2007 6:05 pm
the render engine does not know which face is on top of the other.
on some places it happens to be the first, on others it is the second one I think
even if they are exactly at the same place, at the 7th number after the comma they might be a little bit different
and you get the speckles because one plane casts a shadow on the other one
at least I think so :)
solution: see above post
kitsu
Post by kitsu » Fri Feb 16, 2007 7:00 pm
This is indeed caused by "coincident surfaces" and will render similarly in most renderers.
gray_
Post by gray_ » Mon Feb 19, 2007 3:08 pm
Thanks guys.
I also found that creating a single mesh using Boolean->Union solves this problem too.
- Gray
