Hi all,
Apologies if this is an RTFM question - I have RTFMed and Googled without any luck.
I'm using Blender just for the VSE - to edit together some screen captures I did for a demo for work, basically I want to use blender instead of Camtasia (it's expensive and I don't like the way it works anyway).
I've edited down the video and audio so now my demo plays how I want it. I need to be able to render the sequence into multiple different formats, so I'd like to use the command line so I can render into multiple formats with one script.
The problem I'm having, is that when I try to render my project, it's rendering the default 3D project (the lit cube), rather than my video/audio clips on the VSE timeline.
Is there some way to render the sequence, instead of the 3D scene?
Cheers,
KEv.
VSE Rendering from the command line
Thanks for the link. Checking back on what I originally posted though, my explanation was a bit off.
What I'm trying to do is duplicate what I can do with the GUI (which I already have working, as explained in the documentation) but reproduce it from the command line.
When I run my project from the command line, for example:
blender -b myproject.blend -a -o //output -x 1 -F AVIRAW
It renders the cube, and not my VSE timeline.
I'm sure I'm missing an option, but "blender -h" doesn't mention anything about VSE.
Is there an extra option I need to render my VSE timeline instead of the 3D proiject? Like I said before, I've checked the documentation and googled a lot without any success.
Cheers,
KEv.
Cheers,
KEv.
