blurred textures (turning off filter?)
lean
Post by lean »
hello. I'been using blender for a little more than a year now, and I feel really comfortable with it. However, some time ago I've updated from version 2.49 to 2.6. I often make pixel art textures for my models, and with this latter versions, I'm having trouble getting sharp renders.
I've setted off mimpmaps in the preferences panel, I've setted AA off in Render panel and setted mip maps off in the texture panel.
the last thing that seems to be blurring the texture is the filter at image sampling in the textures panel. I can't set this filter below 0.10 so I uncheck interpolation wich states "interpolate pixels using selected filter" but that doesn't work the filter is still interpolating the pixels.
this problem didn't happen to me with version 2.49.
lean
Post by lean »
bump?
marksism
Post by marksism »
Hi there
I had a similar a problem but solved it by switching on Premultiply and Fields in the Texture properties panel, setting the Fields to Upper First. I have absolutely no idea what either of these functions do but it worked for me, hope it does the same for you.
lean
Post by lean »
hi.
thanks for the reply. I just tried premultiply and fields, and the problem persists.
as I have mipmaps off in preferences, the texture show correctly in the 3d view, but when I render, blender antialiases the pixels.
marksism
Post by marksism »
Hello again
Sorry my suggestions didn't work for you. I've just taken a look at the blend file that initially caused the problem for me and the important factor seems to have been the Fields setting. All I can suggest now is that you replicate the texture settings that worked for me and see what happens.
Fields and Premultiply set as in my previous post.
Image Sampling
Mip Maps- on
Mip Map Gaussian Filter- on
Interploation- on
The Filter type is set to Feline, with Probes at 23 and Filter size to 0.08.
I'm not sure what any of this actually means but my moto is 'If in doubt, switch things on and off at random.' but don't try it if you work in a nuclear power plant or the cardiac ward of a hospital.
Good luck
lean
Post by lean »
hello
ok, so these last settings actually kinda made it worse haha. changing the filter to feline seems to work better but the problem is, as I said in the original post, that the filters can't be set at lesser values than 0.10.
how could you set it to 0.08?
marksism
Post by marksism »
er...the 0.08 was a mistake on my part and you're correct, the filters don't go below 0.1. Sorry about that.
It has occurred to me that the problem might be with antialiasing on the the textures. The blend that gave me trouble was using an image map to put the characters on a model of a QWERTY keyboard. The original texture I created (through PhotoShop) used antialiasing on the keyboard characters and the result, when applied as a Texture in Blender, was a big blurry mess, regardless of the Texture settings used. I went back to PS and remade the texture with AA switched off and found that it worked fine with the Texture settings I suggested earlier.
That's all I can think of- and I'm sorry if it's of no use to you. It's obviously possible to get crisp Texture Mapping in Blender but I think it might take someone with more knowledge to provide the help.
Is there anybody out there?
lean
Post by lean »
so, no one else has had this problem?
lean
Post by lean »
so, should this be reported as a bug or suggestion?
MoonBeans
Post by MoonBeans »
Here's what I use (I get crisp, clear pixels):
Under image sampling:
[ ] Normal Map
[ ] Derivative Map
[ ] MIP Map
[ ] Interpolation
Filter:
[Box]
<Filter Size: 0.10>
[ ] Minimum Filter
I turned off all the check-boxes and set the filter to box.
