GPU rendering card compatibly
Dr. Strangelove
Post by Dr. Strangelove »
I have a radeon hd 4770 gpu card,. will I be able to use it for gpu rendering or will I have to get another one?
[/u]
CoDEmanX
Post by CoDEmanX »
ATI cards don't seem to be useful for gpu rendering:
http://www.blenderqa.com/index.php/216/ ... red-nvidia
in fact, there's not a single ATI GPU render time in benchmarks:
http://www.blender.org/forum/viewtopic.php?t=23793
looks like you should either use CPU rendering or get an Nvidia card
Dr. Strangelove
Thanks for answering.
Dr. Strangelove
BTW, I suppose a geforce 8400 gt can't do this either?
Dr. Strangelove
Wow, all these cards are pretty high for me, I guess I'll have to wait till they come down or someone makes a version that works with my radeon hd4770
Dr. Strangelove
I see some radeon 5 and 6 series cards I can barely afford, I've heard that blender 2.63 can support gpu rendering on these, maybe I'll try one.
It does bug me that it can't support the hd4770 yet, that's a pretty good card, hell, I play bioshock and crysis 2 on it, not at ultra settings of course but passable ones nonetheless.
CoDEmanX
Post by CoDEmanX »
well, why not try Blender 2.63 and OpenCL GPU rendering with your current card?
You can get demo files here:
http://www.blender.org/development/rele ... emo-files/
(cycles + dynamic paint)
bill2reg
Post by bill2reg »
I have Blender 2.63 with an ATI Radeon 5570, and the only option is under the 'experimental' setting, and it says "Redwood", but I haven't been able to find out what that means. As far as I can tell, GPU rendering with my card doesn't work. If anyone has an answer about this "Redwood" thing, please let us all know. Thanks.
CoDEmanX
Post by CoDEmanX »
bill2reg
Post by bill2reg »
Thanks for that link! But now I still can't tell if that means my GPU can be used in Cycles rendering. It didn't seem to go any faster than the CPU, and that's why I wasn't sure if it was using GPU or CPU, regardless of my settings.
Dr. Strangelove
CoDEmanX wrote:well, why not try Blender 2.63 and OpenCL GPU rendering with your current card?
Because when I try gpu rendering I just get told it needs open cl 1.1 and it only found version 1.
CoDEmanX
Post by CoDEmanX »
interesting, AMD released an OpenCL 1.1 related GPU driver in 2010:
http://support.amd.com/us/kbarticles/Pa ... river.aspx
Radeon HD4xxx <-- Thus it should support OpenCL 1.1 ?!
Do you have the latest catalyst driver?
bill2reg
Post by bill2reg »
I have the ATI Radeon 5570 and I have installed the latest driver. (Prior to installing it I couldn't even see "Redwood" as an option under 'OpenCL'). I tried rendering several different .blend files under "Supported" and "CPU" and then using "Experimental" and "Redwood" (GPU), but the render times were almost exactly the same. So.....I'm not sure if it's actually using the GPU or not when I select "Experimental" and "Redwood". Or possibly that my GPU is simply not any faster than my CPU (intel core i7 - 6 cores @ 3.2GHz).
