I was trying out video editing for the first time in blender. I split the view into four parts, the sequence editor set to preview, the node editor, and the render result in the UV image editor.
(If you didn't read the first bit, read this one)
In the node editor, I threw a distort node over a movie clip, just to see if it was working. I then rendered it out to test it. It worked fine, so I went to edit things in the node editor when the FINAL render preview changed as well! Adjusting the distort value placed the effect over the FINAL render preview. No, the UV image editor is NOT set to "viewer node".
Is this a bug? Has anyone else noticed this problem?
Node Editor Changes The FINAL Render Preview?
