renderer as a seperate executable?
dotblend
Post by dotblend »
hello
i simply hate it if blender keeps crashing while rendering so maybe its a solution to put the renderer in a seperate excecutable to prevent blender from crashing while rendering.
peter dotblend
theeth
Post by theeth »
Just render through the command line options in a separate thread. There's a few scripts that do that automaticly from within blender.
Martin
- John Lennon
dotblend
Post by dotblend »
at alatis we developed barbie (Blender Animation Render Batch Interactive Editor) a batchfile maker for blender so i know its possibility's but i want to continue working with blender while rendering... and if it crashes i can simply kill the task and continue working!
theeth
Post by theeth »
http://www.clubinfo.bdeb.qc.ca/~theeth/Render.py
This script takes the current file and render it from command directly from Blender. All you have to do is save the file and hit the ANIM button in the script window (it works for animations, but adapting it for still is probably trivial).
Martin
- John Lennon
macouno
Post by macouno »
why not use BFR (blender file renderer)... do a search at elysiun.. I've found it to work rather well. and well I use anim button for stills all the time, just save with the start and end frame both on the frame you want to render.
dotblend
Post by dotblend »
for larger animations that dont need fancy raytracing i still use 2.12 but it still crashes! i hate it
but i'm gonna try your script theeth! thanks man!
stiv
Re: renderer as a seperate executable?
Post by stiv »
dotblend wrote:i simply hate it if blender keeps crashing while rendering
Did you file a bug report? A quick check did not show one with your name or symptoms.
/me wonders if this is the crash rendering Empties with bad ATI drivers.
dotblend
Post by dotblend »
it could have something to do with empty's but no way with bad ati settings! (nivdia card) not enough ram could also neither be a issue (1 gig)
so i dont know what is...
matt_e
Post by matt_e »
Of course another argument 'for' would be to have an executable that doesn't require X, or OpenGL etc but I'm guessing it's more trouble than it's worth, right? :)
dotblend
Post by dotblend »
it's fairly simple... i have to get about 6000 frames rendered by tuesdaymorning (preferred monday evening) according to my current renderspeed and correction if the .bat file fails it's gonna be friday... unless i find a batch file guru.
that can help me with a few questions i have
it's annoying.
theeth
Post by theeth »
broken wrote:Of course another argument 'for' would be to have an executable that doesn't require X, or OpenGL etc but I'm guessing it's more trouble than it's worth, right? :)
If you run it from command line, can't you run it in a console directly without X?
Martin
- John Lennon
