Raytracing problem with toon shader
drachton
Post by drachton » Mon Apr 19, 2004 4:57 pm
Hi.
I've been working on a skin shader that uses the toon shader. You can see my thread on elysiun here. In any case, I've run into a problem with raytracing.
The scene has only two lamps with raytracing enabled, and the scene is rendered with very standard settings (OSA 16, shadows on). I was wondering if this is a known problem and if a fix is on the way.
Thanks.
