how to do an ice cube?
Aenogym
Post by Aenogym »
hi guys,
i'm new to blender, but i'm starting to really like it :D .
my question is: how to realize an ice cube?
my first problem is the shape: how can i dent it?
and my second problem is the material: how can i create a realistic-looking ice material?
thanks for your answers,
Aenogym
ray_theray
Post by ray_theray »
<First of all, questions about usage of Blender have a better chance at responses at www.elysiun.com - No harm, no foul though :wink: >
For the cube, I would start by adding a mesh cube, and then fractal subdivide each face a little. It could be smoothed out using subsurf.
For the material, it depends on how real you want it to be. You can use raytracing (add some RayMir and RayTrans, turn the Alpha down to around 0.3, darken the color and lighten the specular color and turn up the specularity).
I hope that gives you a start!
-ray_theray
Aenogym
Post by Aenogym »
i already downloaded yafray.
i'll try your solution for the shape.
thanks!
Aenogym
dcuny
Post by dcuny »
Just in case you weren't aware, Blender has a raytracer in it as well, so you can get raytraced transparency and reflections without Yafray.
In Scene mode (Press F10), make sure the Ray button is pressed. This activates ray tracing.
You still have to set the transparency and reflection attributes of the material. In Shading mode (press F5), choose the Material button (the red ball). The third group to the right has two tabs - Shaders and Mirror Transp. Click the Mirror Transp tab to bring up the material properties. Turn on Ray Mirror and Ray Transp.
Aenogym
Post by Aenogym »
yeah, i already did that. but i think blender's internal raytracer doesn't look as good as yafray. AND yafray is MUCH faster than blender's raytracer (especially with OSA on)!
Aenogym
Ringo7
Post by Ringo7 »
Aenogym wrote:yeah, i already did that. but i think blender's internal raytracer doesn't look as good as yafray. AND yafray is MUCH faster than blender's raytracer (especially with OSA on)!
Aenogym
I can't really agree on that, Aenogym, yafray takes forever on my system. Maybe it's something I'm doing (or not doing) but it's definately slower than the built in raytracer here.
