Render raytracing problems
grimey
Post by grimey »
I'm seeing some issues with blender raytracing. Basically, raytracing seems to cause faces not to be rendered. I might even be doing something wrong :?
Blender image with no raytracing
http://www.missouri.edu/~eetge/pics/blnoray.jpg
Blender with raytracing
http://www.missouri.edu/~eetge/pics/blray.jpg
Yafray with ray tracing
http://www.missouri.edu/~eetge/pics/yfhray.jpg
rcas
Re: Render raytracing problems
Post by rcas »
grimey wrote:I'm seeing some issues with blender raytracing. Basically, raytracing seems to cause faces not to be rendered. I might even be doing something wrong :?
Might not be that, but try to recalculate normals outside.
How to use a Blender:
Put your model, rig, animation and textures in the Blender, turn the Blender on and wait for it to Render, then turn the Blender off and show it to your friends.
Caronte
Post by Caronte »
If you use a CVS build... I think thi's a bug.
Caronte.
http://www.nicodigital.com
grimey
Post by grimey »
Negative on recalculate outside, same problem.
Um, CVS build...? I'm using 2.40 alpha 2 installed on win XP pro, so I think so!
I take it then, that this is already reported?
patricks
Post by patricks »
Tray “remove doubles” in edit mod.
grimey
Post by grimey »
There are no doubles to remove
rcas
Post by rcas »
grimey wrote:There are no doubles to remove
Try Unified Render
SirDude
Post by SirDude »
Post the blend file so we can take a look at it.
grimey
Post by grimey »
Ah, the unified render fixed it !
The blend file is at
http://www.missouri.edu/~eetge/pics/coilwithbends.zip
for those interested.
Caronte
Post by Caronte »
This perhaps a bug in the raytraced shadows.
Unified render don't fix it for me, but disabling shadows yes.
Caronte.
softwork
Post by softwork »
No bug, just overlapping faces. The coil is build from several parts, which overlap eachother at the endpoints.
grimey
Post by grimey »
Overlap or not, wouldn't that be a bug?
