Incorrect rendering nearest faces
nixite
Post by nixite »
I too often see incorrect rendering in internal blender render, when two faces placed near each other. I think this is a bug, because yafray render correctly in this case.
See my post with images at elysiun: http://www.elysiun.com/forum/viewtopic. ... highlight=
Is it able to do anything with it to fix this bug for a future...? maybe some options and recompile?
Thanks.
z3r0_d
Re: Incorrect rendering nearest faces
Post by z3r0_d »
nixite wrote:I too often see incorrect rendering in internal blender render, when two faces placed near each other. I think this is a bug, because yafray render correctly in this case.
yafray isn't a scanline renderer, as in it doesn't use a depth buffer.
what you're seeing is called z fighting, and it can't be eliminated in a scanline renderer.
http://en.wikipedia.org/wiki/Z-fighting
LetterRip
Post by LetterRip »
actually the cvs version of blender should be better that 2.41 since the zbuffer implementation was changed which I believe gives greater precision than that of 2.41
LetterRIp
