Blender render performance benchmarked! WinXP,Gentoo,Knoppix
mpan3
Post by mpan3 » Thu Mar 16, 2006 8:05 pm
http://www.mpan3.be/renderspeed.htm
I did a few test and came up with these results, in fact, the test was done quite a long time ago, hence the use of v2.40.
Anyways, here is the scene i used, feel free to give it a try on your system and share your time.
http://www.mpan3.be/files/Blender_Rende ... mark.blend
Rumbl3
Post by Rumbl3 » Tue Mar 28, 2006 3:38 pm
Workstation 01 :
HP XW8200
Processors Bi Xeon 3.6 Ghz
Ram 3.25 GB
GPU Quadro FX 3400
OS Win XP Pro SP2
Re-render gives different times. I don't know why so I give you extreme times.
System Hyperthreading ON - Blender Threads ON : Best 1:24.83 - Worst 1:26.43
System Hyperthreading ON - Blender Threads OFF : Best 2:20.42 - Worst 2:22.32
System Hyperthreading OFF - Blender Threads ON : Best 1:19.95 - Worst 1:20.26
System Hyperthreading OFF - Blender Threads OFF : Best 2:20.78 - Worst 2:20.84
Workstation 02 :
HP XW8200
Processors Bi Xeon 3.2 Ghz
Ram 3 GB
GPU Quadro FX 3400
OS Win XP Pro SP2
System Hyperthreading ON - Blender Threads ON : Best 1:36.88 - Worst 1:38.80
System Hyperthreading ON - Blender Threads OFF : Best 2:36.83 - Worst 2:38.91
System Hyperthreading OFF - Blender Threads ON : Best 1:31.62 - Worst 1:33.12
System Hyperthreading OFF - Blender Threads OFF : Best 2:37.12 - Worst 2:38.88
alelink
Post by alelink » Tue Mar 28, 2006 9:04 pm
hello,
I've done the test on my MacIntel 2ghz 512mb ram (threads on),
using the preview build posted in this forum.
this is the result:
56,21 sec - 8,27Mb used for the rendering
Rumbl3
Post by Rumbl3 » Thu Mar 30, 2006 11:47 am
What's wrong with my poor results, Win XP or Intel ?
ysvry
Post by ysvry » Mon Apr 10, 2006 10:23 am
did you use the intel optimized version? that one goes about twice as fast.
mpan3
Post by mpan3 » Fri Apr 21, 2006 1:53 am
Rumbl3, your time seens ok for a dual core running on XP Pro. Remember that ram size and graphics card doesn't really come into play for this render test. I'd even say that 1:19 is a very impressive time.
alelink, I've read some good feedbacks on the Intel Duo, but 56 sec?! You also mentioned memory usage which threw me off because you SHOULD use around 49mb of RAM to render the image. Is the final result the same as the following pic?
alelink
Post by alelink » Fri Apr 21, 2006 10:54 am
Hello, I have a 56sec of rendertime the first time, next time the render time is around 55/56.
I'll post the render view, so you can see the render value, but I can't download the scene anymore. please send me another link to the scene file
test.
thanks
mpan3
Post by mpan3 » Sat Apr 22, 2006 12:36 am
That's a great time. Can you give us more info on your system? hardware, os, blender version?
And the .blend file is here so you can give it another try: http://mpan3.homeip.net/file.folder/benchmark.blend
alelink
Post by alelink » Sun Apr 23, 2006 12:23 pm
Hello, I'done some render of the scene, and I've posted some screenshot of the renderview;
my system specs are:
iMac Intel 2,0GHZ
512Mb Ram
OSX 10.4.6
I use the first macIntel blender build, at this link: http://www.blender.org/forum/viewtopic.php?t=8337
so, those are the pics (please consider that during render the mem usage is around 41Mb)
mpan3
Post by mpan3 » Sun Apr 23, 2006 4:23 pm
:shock: I am sold, that speed is probably on par with an A64 4200+. You didn't mentio its an intel duo (dual core) so i assume it's just one cpu?!
So after all mac makes an awsome worksation...
DwarvenFury
Post by DwarvenFury » Sun Apr 23, 2006 7:37 pm
They only make dual-core Intel iMacs, so the CPU should be a 2.0 GHz Intel Core Duo.
"What a horrible candle snuffing word. Just."
alelink
Post by alelink » Mon Apr 24, 2006 12:25 am
I'm sorry, I did't say that the iMac is a DualCore.
For the rendering I've enabled the thread option.
mpan3
Post by mpan3 » Mon Apr 24, 2006 1:07 am
DwarvenFury wrote:They only make dual-core Intel iMacs, so the CPU should be a 2.0 GHz Intel Core Duo.
call me an ignorant PC-fanatic who knows nothing about the world outside. :oops:
DwarvenFury
Post by DwarvenFury » Mon Apr 24, 2006 3:03 am
The only reason I knew that was that I'm interested in getting an Intel iMac when I raise the necessary funds.:wink: As long as your PC suits you, there's no need to know about the outside world.:)
