Transparent Objects
SkyRenderX2
Transparent Objects
Post by SkyRenderX2 » Wed Apr 05, 2006 6:44 pm
I have a transparent mesh object which contains a sphere. The embedded sphere doesn't get rendered (I only get a black circle where the sphere should be). However anything else behind the mesh object does get rendered, since the mesh object is transparent. Is there any way to toggle the settings in order to make something visible if it is inside of a transparent mesh object? Thanks for any help.
bmud
Post by bmud » Mon Jul 24, 2006 10:24 pm
I can't seem to replicate your problem.
Kram1032
swich "double sided" off!
Post by Kram1032 » Sun Aug 20, 2006 12:11 pm
Try to swich off "double sided" in Edit-Menu (F9)
Then the inner side shouldn't be rendered...
________________________________________
wild-card character for my future signature!
:D
mpan3
Post by mpan3 » Sun Aug 27, 2006 8:53 am
Make sure you turn on Z-Trans if you are using simple transparency. Or increase the Depth value for ray-traced transparency.
Dekker3D
Post by Dekker3D » Tue Oct 31, 2006 10:39 am
make either the transparant mesh stop casting shadows, or set the sphere to receive transparant shadows.
