Dual core rendering????
bjarnskov
Post by bjarnskov »
Does blender support dual core rendering? Like 3ds Max?
I know there is somekind of build that should support conroe's, but is it just optimized, or real dual core rendering?
89ers
Re: Dual core rendering????
Post by 89ers »
bjarnskov wrote:Does blender support dual core rendering? Like 3ds Max?
I don't really know what you think when you are talking about "dual core rendering", but the renderer of Blender is multithreaded, which means that you can use the power of your dual-core machine to render...
In fact, i have a Core Duo MacBookPro, and it renders when i'm typing this post at full throttle (100% on each core...)
Hope it helps ! :)
Regards,
Laurent aka Tartiflette :)
Caronte
Post by Caronte »
Push the THREADS button on F10 window.
Caronte.
http://www.nicodigital.com
bjarnskov
Ok
Post by bjarnskov »
Thanks, both of you, it was just what i needed to hear.
89'ers: When i say dual core rendering i mean rendering with boths cores, some programs only allow one
Caronte: What an awesomely cool function, blender just got soooo much cooler (Actually, for me, it gets cooler every day, as i learn new functions). Are there anything else "hidden rendering secrets" you can tell me about :wink:
Caronte
Re: Ok
Post by Caronte »
bjarnskov wrote:Are there anything else "hidden rendering secrets" you can tell me about :wink:
Sure, but is more funny to discover it yourself ;)
Caronte.
tsodzil
Post by tsodzil »
I have a render problem with threads:
If I use the UI and push the render-button -- after pushing Threads of course -- I have a render time of 1'30".
I upgraded my blender-usersettings via CTRL-U to keep the Thread setting on.
However, if I render via the CLI (blender -b scene.blend -s 1 .....) I have rendertimes about 2'40", which looks to me as the Thread-stuff is not enables by the CLI.
Any ideas?
Caronte
Post by Caronte »
tsodzil wrote:I have a render problem with threads:
Any ideas?
The thread is not set by usersettings, but on the .blend
Caronte.
tsodzil
Post by tsodzil »
ah, now I understand, thanks a lot :)
lareon
Post by lareon »
I have an Intel iMac (original generation), and whenever I render with Threads enabled, it's faster, but I also get artifacts which are not present without Threads enabled. Is this a known bug or something that's just my machine?
--Scott
LetterRip
Post by LetterRip »
hmm not a known bug that i know of - please post the blender and image to the tracker... also try with current cvs...
LetterRip
LazyCoder
Post by LazyCoder »
Has anybody tried rendering with a quad core? I was thinking of getting one.
RoyBatty
Post by RoyBatty »
I have Pentium 4 Northwood @ 3722 MHz with Hyperthreading enabled and when Threads button is enabled the rendering is slower, is this normal? Does it work on dual-core CPUs only?
Threads enabled
Append frame 20 Time: 01:09.22
Append frame 21 Time: 01:08.88
Append frame 22 Time: 01:08.40
Append frame 23 Time: 01:07.68
Append frame 24 Time: 01:07.11
Append frame 25 Time: 01:06.28
Threads disabled
Append frame 20 Time: 00:57.51
Append frame 21 Time: 00:56.56
Append frame 22 Time: 00:56.40
Append frame 23 Time: 00:56.01
Append frame 24 Time: 00:55.19
Append frame 25 Time: 00:54.93
I didn't find anyting about this in the Blender wiki...
sarah
Post by sarah »
LazyCoder wrote:Has anybody tried rendering with a quad core? I was thinking of getting one.
I have a Mac Pro (quad core Xeon) at work and blender runs very nicely on it. The internal renderer (2.42) seems to only offer one thread or two. Yafray will use four threads, and it's very nice. Even rendering on two cores, though, it's nice to still be able to continue to work normally on the two remaining cores; the machine stays completely responsive at 200% cpu!
My Mac Pro has 4gig of ram... which turns out to be not as much as it used to be! When running Linux and Windows in Parallels VMs, plus blender, plus a couple web browsers, the machine starts to swap. Usually I try to only run Linux in Parallels and I manage to get by somehow...
Now I'm dreaming of an eight-core Mac for home! Hopefully by then the internal renderer will use all eight cores.
stiv
Post by stiv »
Next release has a cute little Threads button in the Render Output panel that goes up to 8. You can see it in the release candidates.
sarah
Post by sarah »
stiv wrote:Next release has a cute little Threads button in the Render Output panel that goes up to 8. You can see it in the release candidates.
1. Yay!
2. I *have* looked at the RC, but only briefly. Missed that bit, obviously.
3. Why doesn't it go to 11? :-)
4. No, seriously, why is 8 threads the limit? What if I'm running on some enormous piece of hardware that can support 2048 threads or something?
