How to use multiple UV layers with glsl shaders in GE?
grzybu
Post by grzybu » Tue Jun 10, 2008 2:44 pm
I can't get multiple UV layers work with glsl shaders. I can only get access to first layer and it works fine. But if I want to multiple lightmap with diffuse layer it don't work.
I thought that instead of using gl_TexCoord[0].xy I should call gl_TexCoord[1].xy but then I have white object.
When I don't use glsl shader, GE renders diffusemap + lightmap correctly with different UV layers. But I need normalmapping and everything works fine but lightmap with second UV layer.
OTO
Post by OTO » Tue Jun 10, 2008 11:27 pm
Hello
have you read the "light map" tutorial?
http://www.continuousphysics.com/lightm ... orial.html
Bye
grzybu
Post by grzybu » Tue Jun 10, 2008 11:54 pm
Sure, but I want to use lightmap in glsl shader. It works fine with default blender shading like in this tutorial. I just can't get second UV layer coordinates for lightmap in glsl shader.
grzybu
Post by grzybu » Mon Jun 16, 2008 4:48 pm
OK, I've found solution. I just forgot to add line:
gl_TexCoord[1] = gl_MultiTexCoord1;
