Can someone help me with Sensors? Thank's
madcello
Post by madcello » Sun Aug 17, 2003 7:32 pm
Here is the case.
I have more than one door in a house, and i wan't to to use the (Right Mouse click Sensor) to open the doors (but just "that" door expecificaly).
Already have the realtime thing working almost the way i want, but when Right click, all doors open or close at the same time.
Is possible to do what i want?
Thank you very much!
thoro
Post by thoro » Wed Aug 20, 2003 6:05 pm
Hi!
You have to combine 2 sensors, the 'Mouse'-sensor that you already assigned and an additional 'Near'-sensor, using an 'And'-controller.
This should do the trick :-)
Cheers
Thorsten
Saluk
Post by Saluk » Wed Aug 20, 2003 6:28 pm
Come check out elysiun.com, it's a better place for your questions:)
This site is more geared to programming the engine itself, rather than making things with it.
thoro
Post by thoro » Wed Aug 20, 2003 7:12 pm
...oops, was my answer that bad? :wink:
Saluk
Post by Saluk » Wed Aug 20, 2003 7:56 pm
lol, your answer was fine, but people are supposed to keep these sorts of questions on elysiun, while talking about development or bugs here :)
madcello
Post by madcello » Thu Aug 21, 2003 1:02 am
After trying a while :shock: , saw that the doors have to be actors for the Near sensor to react, and react :o (just have to test the values)
:D Thank you very much for your help, thoro!
p.s. - I've put the same question in elysiun.com, before put it in here, and got no help (and dont think the question so "dummy" or "Empty" (bad joke) in this forum.
thank's again!
Good Blending!
verence
Post by verence » Thu Aug 21, 2003 12:33 pm
just a small hint, it is easier to combine two mouse sensors: rmb and mouseover, so you do not have to play with values.
greets,
verence
madcello
Post by madcello » Thu Aug 21, 2003 2:32 pm
Good, it's better for me because i'm making aninteractive house and there are doors close to each other.
This gives (in this case) a hell of much more control! :D
